| weak sector, finally a program able in resolving this prob.. http://forum.hddguru.com/viewtopic.php?f=7&t=12390 |
Page 1 of 1 |
| Author: | danrevella [ May 31st, 2009, 15:01 ] |
| Post subject: | weak sector, finally a program able in resolving this prob.. |
HI!!! Finally a software who take care about slow/bad sector: pick it here: http://www.piotrkn22.republika.pl/drev/index.html It is also incredible fast!!!! |
| Author: | drc [ May 31st, 2009, 17:04 ] |
| Post subject: | Re: weak sector, finally a program able in resolving this prob.. |
website in the link wrote: The surface of almost any drive can be repaired with this utility (even hard drives that were dropped down or exposed to strong electromagnetic fields). |
| Author: | zed [ May 31st, 2009, 18:51 ] |
Anybody used this program yet? Any feedback? |
| Author: | HardDiskBug [ June 1st, 2009, 2:53 ] |
It's a program, based upong stealing the source code from HDD Regenerator. So guys, you all know about the original HDD Fu...I mean, Regenerator. So, you can easily guess about a pirated HDD regenerator. |
| Author: | danrevella [ June 1st, 2009, 9:07 ] |
Maybe.... But I don't believe...... The weak sectors repair is a new piece of code I never seen before.... I have just de-slowed 4 hd...... Are you sure you have really try to use this program? To test result, i have used Victoria for Windows 4.3 then comparing the log of the slow sectors before and after drevitalize.... After using Drevitalize with retry 10 and ms: 80 , I get NO MORE slow sector on my hd. If this is a hd-killing application, I may assure that at least 4 hd were in fact full re-vitalized, and NOT killed.... BTW I have still 12 very old hd to try.... I'll let you know!! |
| Author: | N.C. [ June 1st, 2009, 9:26 ] |
danrevella wrote: Maybe.... But I don't believe...... The weak sectors repair is a new piece of code I never seen before.... I have just de-slowed 4 hd...... Are you sure you have really try to use this program? To test result, i have used Victoria for Windows 4.3 then comparing the log of the slow sectors before and after drevitalize.... After using Drevitalize with retry 10 and ms: 80 , I get NO MORE slow sector on my hd. If this is a hd-killing application, I may assure that at least 4 hd were in fact full re-vitalized, and NOT killed.... BTW I have still 12 very old hd to try.... I'll let you know!! This can happen if you simple re-write all the sectors, no wonder or magic. Some hdd can survive this, some not. Janos |
| Author: | HardDiskBug [ June 1st, 2009, 10:50 ] |
Dan, I remember, you had created some sort of bad/slow sectors marking utility. Though, I never checked that, but I believe, it kinda was usefull and working. So, why bother to go for such craps? Well, I may sound like biased..so, a test for you. The rest of the 12 drives you have, pick a couple of them, run a Full ZEROFILL (If want to test it in a geek way, you can also run a full verify-write-verify)...then see the drive's status. After that, run the Drevital...let it do it's work...and compare the results (If there are any)... It's simple! |
| Author: | danrevella [ June 1st, 2009, 14:42 ] |
HardDiskBug wrote: The rest of the 12 drives you have, pick a couple of them, run a Full ZEROFILL (If want to test it in a geek way, you can also run a full verify-write-verify)...then see the drive's status. After that, run the Drevital...let it do it's work...and compare the results (If there are any)... It's simple! I would like to perform this test..... BTW what you mean about ZEROFILL? Have i to use a LLF like f.e. "HDD LLF Low Level Format Tool 2.36" If this is what you mean, I may tell you that on all my defective HD I have try it before, but the slow sector were never revitalized..... For that reason, till now I use my "makebad" utility to change the slow sectors in UNC, but "Drevitalize 2.30" DOES WORKS!!! Or maybe you were not speaking about HDD LLF Low Level Format Tool 2.36 ? Thanks for help!! danrevella |
| Author: | N.C. [ June 1st, 2009, 14:50 ] |
danrevella, read this topic to be more clever. healing-slow-blocks-erasing-durable-t9782.html Janos |
| Author: | danrevella [ June 1st, 2009, 17:22 ] |
Ok.... I have read...... In other word I have to expect that the just de-weaked sector in the next time will revert to weak..... ok.... I'll keeep an eye on the log files, see you later in 2-3 weeks....... BTW I am speaking about hd very old and with not important data: hd were the g-list is just full, and also I speak under the perspective of an user who may NOT buy a pci3000 to repair hd.... I have also try to use an other utility: "repartition bad drive", but it create on an hd 37 (yeah!! 37!!) partition...... unaccetable..... Thanks to all for the help. |
| Author: | Petersx [ June 15th, 2009, 11:10 ] |
HardDiskBug wrote: It's a program, based upong stealing the source code from HDD Regenerator. I will ask you one question HardDiskBug. What proof do you have that DRevitalize is based upon stealing the source code from HDD Regenerator? Becasue the fact that something also repairs (in some cases relocates) bad sectors by writing/reading some patterns to the disk surface is no proof at all. What more, a detailed explanation on how HDD Regenerator works can even be read at Nazyura's website (you can translate the page via google translator if you don't know Russian). Writing/reading patterns like 00s, FFs or others to the disk surface can not be protected by any patent and as such the author of HDD regenerator has to live with the fact that other applications doing the same job will be written. It's just a question of time and a few experiments to come up with an effective rewrite/or relocate bad sector loop algorithm. This is not some super code or extra manufacturer commands! Besides there is no way two programs that differ so much in functionality can have identical code. DRevitalize documentation is correct and points out all the truth about revitalizing drive surface without hiding the fact that in some cases it will relocate bad sectors. On a side note I'm pretty sure that if I have enough time (DRevitalize is and has always been a hobby project), the next release of the program (2.40) with it's possibilities will leave HDD Regenerator far behind. I wasn't registered on this forum (because it is basically limited to PC3K and Salvation data products use) but your false statement actually forced me to do so. I've explained and pointed out everything clearly and consider the issue closed so I will not answer to more posts. PETERS The author of DRevitalize |
| Author: | bnice [ June 15th, 2009, 20:39 ] |
Petersx wrote: I wasn't registered on this forum (because it is basically limited to PC3K and Salvation data products use) but your false statement actually forced me to do so. I've explained and pointed out everything clearly and consider the issue closed so I will not answer to more posts. PETERS The author of DRevitalize Yes Salvation and ACE here, and many more. Peters you could discuss more DRevitalize here, don't be upset with a few. Your english is good, would be useful to make an english version web page for DRevitalize. So people can read without using a translator, while making DRevitalize known to a bigger audience, if needed. |
