New version of HDDScan 3.2 is available
http://forum.hddguru.com/viewtopic.php?f=7&t=12688
Author:  Doomer [ July 7th, 2009, 23:21 ]
Post subject:  New version of HDDScan 3.2 is available
http://hddscan.com
Author:  -BR- [ July 8th, 2009, 1:08 ]
Post subject:  Re: New version of HDDScan 3.2 is available
great software, congratulations! :D
if you permit I would like to suggest 3 things:
#1 quick access button for verify and read scan (like you have for smart)
#2 configurable option for whenever you start a scan the map or graph pops up automatically
#3 an option to permanently dock the floating log
-BR-
Author:  poehere [ July 8th, 2009, 1:39 ]
Great job nice program TKX
Author:  Doomer [ July 8th, 2009, 9:18 ]
-BR-
I was fighting with option 2 code for a long period of time. So far I'm losing :)
Can you explain option 3? I'm not quite sure what is a floating log
Author:  -BR- [ July 8th, 2009, 9:32 ]
I mean test manager window is should "dock" or connect to HDDscan window, so when you move Hddscan windows the test manager windows move along
Otherwise if you need to move the program you have to move 2 windows everytime
I hope my comments help to make an even better software
Thank you
-BR-
Author:  Doomer [ July 8th, 2009, 10:33 ]
I got it
That's good idea
I was thinking actually combine both windows together
Author:  zebong [ July 8th, 2009, 14:46 ]
Very good Doomer, great work.
Is possible to use the command line to send commands to the SCSI disk with LBA 0 ?
Author:  beto [ July 8th, 2009, 15:27 ]
zebong, u can did that with any CDB sequencer, means send SCSI commands
Author:  Doomer [ July 8th, 2009, 15:45 ]
No
Author:  drc [ July 8th, 2009, 18:32 ]
What is the "Disable Seagate PM" button? I have a 7200.11 that spins down after it has been idle for a while even though nothing is telling it to so then windows freaks out and gives me all kind of timeout messages, but this button does not seem to help. The normal power management is set to disabled, so I'm not sure why it insists on doing this.
Author:  quasimodo [ July 8th, 2009, 19:49 ]
I never used your tool Doomer, but the GUI looks really nice. I am glad to see that with both Maysoft and Doomer, there are finally some great DR and HD testing tools with nice looking and functional user interfaces. :D
Just out of curiosity, what language did you code your GUI with?
Author:  Doomer [ July 8th, 2009, 19:52 ]
It should be in the docs ;)
It has to disable some Seagate special spin down mode when regular power management doesn't work
Author:  Doomer [ July 8th, 2009, 19:54 ]
I use Delphi 32 from BDS 2006 and AlphaControls - http://www.alphaskins.com/index.php
Author:  quasimodo [ July 8th, 2009, 19:57 ]
I totally digg the skins.
again, Great job Doomer.
Author:  hdd_sand [ August 11th, 2009, 11:55 ]
Nice utility, but why not have a DOS version that I can put in a USB so I can diagnose drive without loading windoze, also any plans to add cloning drive to this application?
Author:  Doomer [ August 11th, 2009, 12:16 ]
if you make one it would be really nice
no, I don't have such plans
