 Post subject: Seagate 7200.10 3.AAD Firmware
PostPosted: July 16th, 2009, 20:41
Anyone have any firmware for the Seagate Barracuda 7200.10 that will work for FW version 3.AAD? I locked my HD... (actaully this idiotic feature on the drive locked it without me knowing) and I can't install linux.
Thanks.
 Post subject: Re: Seagate 7200.10 3.AAD Firmware
PostPosted: July 28th, 2009, 8:28
is there any nice physical data recovery softwares?
pls let me know. thanks!
PostPosted: July 28th, 2009, 8:51
With the exception of building your own terminal adapter, learning the Seagate commands, a lot of frustration and the chances of completely destroying the drive, other solutions will cost a lot of money...in the thousands of dollars. If the data is what you are after, get the drive assessed by a professional. If it is just a matter of salvaging the drive, buy a new one or try for an RMA.
If you are looking for a recommendation for someone in your area, I'd say Doomer is your best bet.
