MHDD able to copy PCB-FLASH information?
http://forum.hddguru.com/viewtopic.php?f=7&t=13025
Author:  Rob2222 [ August 17th, 2009, 13:34 ]
Post subject:  MHDD able to copy PCB-FLASH information?
is MHDD able to extract information from the controller of a WD1600BEVS-07RTS0 from a half-bad (working for 30 seconds) PCB to a good one?
I opened a hardware thread here:
pcb-swap-wd1600bevs-07rts0-good-pcb-here-already-t13024.html
BR and thanks in advance
Robert
Author:  Nirvanowiec [ August 17th, 2009, 16:55 ]
Post subject:  Re: MHDD able to copy PCB-FLASH information?
http://yura.projektas.lt/files/wd/mhdd/wd_royl_rom.html
http://yura.projektas.lt/files/wd/mhdd/index.html
Author:  Rob2222 [ August 17th, 2009, 19:38 ]
Thanks for the link.
In the scripts is a RESET command. My MHDD version only knows the RST command. Do I need a older version?
Another thing is which areas I need to copy and with which command to write back the files?
BR
Robert
Author:  Nirvanowiec [ August 18th, 2009, 3:39 ]
MHDD 4,5
http://yura.projektas.lt/files/wd/hddlsct/index.html
http://www.t13.org
Author:  Rob2222 [ August 18th, 2009, 12:51 ]
Has anybody here the english HDDL 3.1 version? :|
Author:  Rob2222 [ August 18th, 2009, 16:38 ]
Does anybody know the vendor specific command for writing data back to the marvell flash on WD marvell drives?
