| ST340015A http://forum.hddguru.com/viewtopic.php?f=7&t=13131 |
Page 1 of 1 |
| Author: | moby911 [ August 27th, 2009, 16:30 ] |
| Post subject: | ST340015A |
Hi guys I have a problem with my Seagate Barracuda 5400.1 (ST340015A) hard drive. It becomes useless due to firmware corruption, currently it has f/w 3.01 installed. This damage was done to my hard drive when I was transfering some data between two hdds a power surge occurs, I was unable to boot after the power was restored then when i entered in the BIOS I became The detection was ST341015A ! ! ! ! ! ! ! ! instead of ST340015A. Now how can I restore or update its firmware, I tried to search over the internet but all of my efforts ended in smoke.Im 100% sure its a firmware problem because most of the hdd reparing softwares like HDAT2 reports the firmware is corrupted but they were unable to repair this just giving un-correctable CRC errors.Please don't tell me about softwares like a-ff repair station or salvation data etc... I assure you that my Hard Drive is not internally damaged, its quite old but still in a good working condition and cables are also perfectly attached. I would be thankful 2 you if you tell me the name of any free hdd firmware writing software (except salvation data & aff-repair station) in your knowledge or if you can give me the link of seagate firmware update utility which is designed for my hard drive. Thanks ! |
| Author: | rameez [ September 1st, 2009, 11:13 ] |
| Post subject: | Re: ST340015A |
Its a pcb issue change it the drive will start working properly again . |
