| UFS Explorer - Soft RAID, "Not Resolved" folders http://forum.hddguru.com/viewtopic.php?f=7&t=13595 |
Page 1 of 1 |
| Author: | dobrevjetser [ October 8th, 2009, 9:51 ] |
| Post subject: | Re: UFS Explorer - Soft RAID, "Not Resolved" folders |
This means that the information in the XFS filesystem to locate the files is missing due to some kind of corruption. Had this on several occasions also. Dobre |
| Author: | HDD Spaz [ October 9th, 2009, 4:46 ] |
Have you tested any files to see if you have correct raid parameters? |
| Author: | DArk_Janna [ October 9th, 2009, 6:29 ] |
Have you try to find any information on official site? ...may be this will help http://ufsexplorer.com/rdr_xfs.php |
| Author: | Odiferous [ November 15th, 2009, 5:41 ] |
Did you allow the scan to run to completion? This is necessary with UFS Explorer, and aborting the search early often gives you "unresolved" issues. Duncan |
| Author: | continuum [ February 1st, 2011, 2:58 ] |
Anyone have any luck with this? I have two at the moment with this issue. I suspect that the second disk has a number of sectors that are offset from the beginning, but I am unable to find out how many. i have tried several combinations, but none seem to work. I we could only see the hex for the directories, I would be able to see how much they are offset by. Anyone know of any other software that sees xfs? |
| Author: | DR-Kiev [ February 1st, 2011, 5:39 ] | ||
| Post subject: | Re: UFS Explorer - Soft RAID, "Not Resolved" folders | ||
continuum wrote: Anyone have any luck with this? I have two at the moment with this issue. I suspect that the second disk has a number of sectors that are offset from the beginning, but I am unable to find out how many. i have tried several combinations, but none seem to work. I we could only see the hex for the directories, I would be able to see how much they are offset by. Anyone know of any other software that sees xfs? Find this metadata on each drive (the end precedes of this sector) . This will help you correctly bridge the JBOD.
| Author: | continuum [ February 1st, 2011, 20:22 ] |
Still no luck. There is a partition table on the first drive, but the second drive is blank until sector 1006592 where there is another XFS BS. I tried to use this to join the two disks, but no luck. |
