| undo "diskpart -clean" command? http://forum.hddguru.com/viewtopic.php?f=7&t=13649 |
Page 1 of 1 |
| Author: | Lost1 [ October 14th, 2009, 17:38 ] |
| Post subject: | undo "diskpart -clean" command? |
Hello! Is there a way to undo the "diskpart -clean" command if nothing has been done with the drive after it? What tool is best to use? Testdisk? Thanks in advance and best regards! |
| Author: | Zero Alpha [ October 16th, 2009, 9:10 ] |
| Post subject: | Re: undo "diskpart -clean" command? |
Why not check against the FAT? |
| Author: | Lost1 [ October 16th, 2009, 19:24 ] |
Sorry, don't know what you mean. The drive was NTFS not FAT. |
| Author: | Zero Alpha [ October 16th, 2009, 23:47 ] |
Right sorry MFT then? |
| Author: | Lost1 [ October 17th, 2009, 8:11 ] |
Okay, thank you. I will try to repair the MFT with TestDisk when I get my hands on the HDD again. |
| Author: | poehere [ October 19th, 2009, 19:29 ] |
get a partition repair or recovery program to do this one for you it is better than test disk and can remout your patition table and find it for you if it is not too badly damaged or is in a bad sector on your drive. But the looks from your screen shot you should be able to do this with a good partition recovery program. |
| Author: | Lost1 [ October 20th, 2009, 5:48 ] |
Can you recommend a good partition recovery program that works under Win7 or at least can create a boot disk? I didn't have the time yet to try to repair the MFT with TestDisk. Thank you! |
| Author: | Lost1 [ October 20th, 2009, 14:29 ] |
I tried to repair the MFT with TestDisk but it says that the MFT and MFT mirror are bad.
