| bushound .analyzer for capturing I/O http://forum.hddguru.com/viewtopic.php?f=7&t=14055 |
Page 1 of 1 |
| Author: | Persia2500 [ November 24th, 2009, 20:48 ] |
| Post subject: | bushound .analyzer for capturing I/O |
http://www.perisoft.net/bushound/index.htm I though it would be help full for those of you interested in reversing or analizing or debuging . Bus Hound is the premier software bus analyzer for capturing I/O, protocol, and performance measurements. Bus Hound can also be used to build and submit commands to devices including bus resets, from a graphical interface. Power User Features: · Capture megabytes of I/O at a time · View I/O on screen in real time · Trigger on conditions · Build and submit custom commands · Issue bus and device resets · Capture the system startup process · View low level protocol including SCSI sense data and SMART commands · View microsecond resolution timing · Drag and drop captured data to other applications or save it to a zip file · Capture isochronous and control transfers · View IRPs and other device driver packets Bus Support USB 1.0 & 2.0 SCSI & ATAPI IDE & SATA FireWire, 1394a/b Bluetooth Fibre Channel iSCSI, SAS PC Card, PCMCIA serial port parallel port ps/2 ports ...and more OS Support 32-bit and 64-bit Windows 2008 Windows Vista Windows 2003 Windows XP Windows XP Embedded Windows 2000 Windows NT 4.0 Windows Me Windows 98 Windows 95 Device Support DVD, CD, Blu-ray Hard drives, tape drives Removable drives Web Cams, Cameras Mice, Keyboards, HID Printers, Scanners Speakers, Modems ...and everything else! http://www.perisoft.net/bushound/index.htm |
| Author: | Doomer [ November 24th, 2009, 23:03 ] |
| Post subject: | Re: bushound .analyzer for capturing I/O |
using it since version 5 |
| Author: | guru [ December 3rd, 2009, 8:37 ] |
pretty good piece of SW. I have used it for a few years. DataTransit also make some good kit if your into more hardcore reversing and debug. |
| Author: | Persia2500 [ April 6th, 2010, 5:32 ] |
guru wrote: pretty good piece of SW. I have used it for a few years. DataTransit also make some good kit if your into more hardcore reversing and debug. Your advice happened to become very useful hint on specific project. Thank you |
