 Post subject: Writing backup files to a harddisk using MHDD version 4.6
PostPosted: January 4th, 2010, 15:46
I have used MHDD version 4.6, and is to some extent familiar with the application. It is powerful and I have succeded in doing repair and configuration of disks. I have a full backup of a disk using the ATOF command which has created a set of files with increasing numbers, also including file names as xxxx000A, xxxx000B, xxxx000C etc. How can I write this set of files back to a hard disk in an efficient way? Is there a "automatic" command for doing this? It is a rather extensive jobb to perform the FF command for each file, also punching in the start and end LBA-number for each file!!
 Post subject: Re: Writing backup files to a harddisk using MHDD version 4.
PostPosted: April 17th, 2015, 4:49
how did u do the backup using atof command
Users browsing this forum: No registered users and 32 guests
