 Post subject: anysoftware to repair windows embedded
PostPosted: March 29th, 2010, 0:31
this has been driving me nuts :mrgreen:
windows xp system embedded
is there any program out there that can repair the bootup and startup of this system
cheers guys
 Post subject: Re: anysoftware to repair windows embedded
PostPosted: April 1st, 2010, 0:23
oh boy this is driving me nuts
surely someone knows how you can repair a windows embedded system :mrgreen: :shock:
PostPosted: April 1st, 2010, 4:42
cheers guys
How about some details?
Are you having trouble with a particular system?
If so, what I/O devices do you have? Which CPU? Does it have a debug port? RS232? USB?
PostPosted: April 1st, 2010, 7:05
ok the details are that its my arcade machine which has windows xp embedded on it
windows should load up first and does nothing.
was working fine
machine does not boot at all
starts up and remains blank screen
its corrupt start up or boot
ram is working 100%
motherboard 100%
its got a rs232 power and usb
PostPosted: April 1st, 2010, 19:39
Can we see a photo of the setup?
BTW, what makes you think that software will repair your hardware? Have you done some basic tests, like checking the power supply voltages? How do you know that your display is OK? How did you test your motherboard?
For component level technical advice, you may like to visit the sci.electronics.repair newsgroup. I believe there are also specialist arcade forums and newsgroups that are better suited to your question.
PostPosted: April 1st, 2010, 23:42
Black screen how fun. Normally is virus have yiou tried to pull this drive and do a virus scan on it? All the ones that come to me are virus that cause this problems. Normally after virus scan you can start it up again or at least I can. But pull and scan on another sytem
Iorana Haraharaini
PostPosted: April 2nd, 2010, 5:14
it wont be a virus as its not connected up to anything on the net
here what the unit looks like big box looks like a pc system
http://www.system16.com/hardware.php?id=678
yep checked the power supply works fine power tester unit no overloads
got a hardware tester card not a cheap crappy china one
motherboard checks out 100% ram is fine
was working but we had a power cut and the machine was on and now it loads up blank screen nothing else.
so the bootup is corrupt or start up
just wondering how you can repair this type of windows xp embedded systems
OS : Windows XP Embedded (customized)
CPU : Celeron 2.5Ghz (upgradable to Pentium 4 2.8GHz)
FSB : 400MHz (Upgradable to 800MHz)
Chipset : Intel 865G
Memory : DDR266 DIMM 256MB (upgradable to DDR400 2GB)
Graphics Board : AGP Radeon 9200SE (128 MB) through to X800XT (256 MB) (complete ATI Radeon Range)
Audio : AC97 onboard 6 channel audio CODEC
Lan : On-board 10/100Base-TX
USB : 4ch (ver 1.1 & 2.0 compatible)
Parallel port : 1 port
PS/2 port : keyboard, mouse
PCI : 2 slots
IDE : 2ch U-DMA(100/66/33)
Serial ATA : 2ch
Audio inputs : Microphone (stereo pin-jack), line-in (stereo pin-jack)
Audio outputs : line-out (stereo pin-jack), SPDI/F
Power : ATX AC 100v
cheers all
