| corrupt excel docment http://forum.hddguru.com/viewtopic.php?f=7&t=15338 |
Page 1 of 1 |
| Author: | craig6928 [ April 3rd, 2010, 18:09 ] |
| Post subject: | corrupt excel docment |
family member tried to recovery there tax information as its needs to be in this week. they deleted the file to begin with. and recovered it with a program. they sent me the file in excel 2003 and it opens up but its got corrupted lettering all over does anyone know how to rebuild the file system as i tried some programs and they dont work. |
| Author: | dick [ April 4th, 2010, 5:23 ] |
| Post subject: | Re: corrupt excel docment |
Probably the file was partially overwritten. What are you after? A working file or the data contained within? If there is any data to be had you would be able to see it if you open the file in notepad. |
| Author: | craig6928 [ April 6th, 2010, 0:14 ] |
im trying to get the data contained. if i can get working file that be great. but when the files are opened up it contains corrupt information any ideas as i tried opening in notepad etc |
| Author: | pcimage [ April 10th, 2010, 4:38 ] |
I bet they installed the recovery program on the same drive they deleted the file from. |
| Author: | craig6928 [ April 11th, 2010, 19:17 ] |
yep you are correct they did install it on the same drive. the data is gone forever. they have to now go throu all there taxes again. |
| Author: | heutenitaz [ April 22nd, 2010, 3:52 ] |
I know one solution regarding the repairing the file To manually repair a file 1. On the File menu, click Open. 2. In the Open dialog box, select the file you want to open, and click the arrow next to the Open button. 3. Click Open and Repair, and then choose which method you want to use to recover your workbook. |
| Author: | craig6928 [ May 1st, 2010, 3:10 ] |
yep tried that no look the files where half over written so no good thanks all |
| Author: | einstein9 [ June 28th, 2010, 1:32 ] |
craig6928 remember that all office applications create a backup file while your working on the main file i suggest to look @ the temp folder of the user example: MS-word files temp names starts with ~Wxxxx just rename it to .doc and thats it i don`t remember the excel temp name chk it about fixing your file try to use the Kernel for Excel Recovery i tried it the best |
| Author: | craig6928 [ June 29th, 2010, 3:52 ] |
yep checked there and nothing at all the hard drive gone back now as they had to file there tax returns right away thank you |
| Author: | einstein9 [ July 11th, 2010, 6:29 ] |
:> u welcome |
