 Post subject: MHDD: Catastropic failure
PostPosted: April 26th, 2010, 11:51
I was trying out "erase delays" in MHDD on a new WD2001FASS 2TB, but got this message after a while:
* * * CATASTROPHIC FAILURE * * *
Drive hangs on erase sectors.
Why did that happen? Does it mean the drive is bad? It was throwing several warnings (WW) during the diagnostic.
 Post subject: Re: MHDD: Catastropic failure
PostPosted: April 28th, 2010, 7:59
It means that your drive has serious problems beyond MHDD possibilities. Yes, according to this scenario it's bad. RMA if possible , get pro service for repair or get a new one.
PostPosted: April 28th, 2010, 8:36
In a couple of situations I have seen MHDD show "catastrophic failure" messages incorrectly.... though if you were getting other warnings then that may not be the case.
PostPosted: April 28th, 2010, 9:05
Arent these disks the ones with 4kb sectors? Maybe MHDD cant handle these
PostPosted: April 28th, 2010, 9:26
The new "advanced format" drives emulate 512-byte sectors to the interface, so I don't think that should make any difference.
PostPosted: April 28th, 2010, 12:33
Depends if MHDD is setup for correct 48bit LBA support I guess. Maybe ask the author?
Users browsing this forum: Google Feedfetcher and 16 guests
