| MHDD: Catastropic failure http://forum.hddguru.com/viewtopic.php?f=7&t=15578 |
Page 1 of 1 |
| Author: | Pixel Eater [ April 26th, 2010, 11:51 ] |
| Post subject: | MHDD: Catastropic failure |
I was trying out "erase delays" in MHDD on a new WD2001FASS 2TB, but got this message after a while: * * * CATASTROPHIC FAILURE * * * Drive hangs on erase sectors. Why did that happen? Does it mean the drive is bad? It was throwing several warnings (WW) during the diagnostic. |
| Author: | BlackST [ April 28th, 2010, 7:59 ] |
| Post subject: | Re: MHDD: Catastropic failure |
It means that your drive has serious problems beyond MHDD possibilities. Yes, according to this scenario it's bad. RMA if possible , get pro service for repair or get a new one. |
| Author: | drc [ April 28th, 2010, 8:36 ] |
In a couple of situations I have seen MHDD show "catastrophic failure" messages incorrectly.... though if you were getting other warnings then that may not be the case. |
| Author: | hddguy [ April 28th, 2010, 9:05 ] |
Arent these disks the ones with 4kb sectors? Maybe MHDD cant handle these |
| Author: | drc [ April 28th, 2010, 9:26 ] |
The new "advanced format" drives emulate 512-byte sectors to the interface, so I don't think that should make any difference. |
| Author: | guru [ April 28th, 2010, 12:33 ] |
Depends if MHDD is setup for correct 48bit LBA support I guess. Maybe ask the author? |
