| Looking to recover corrupted PSD after power failure http://forum.hddguru.com/viewtopic.php?f=7&t=15758 |
Page 1 of 1 |
| Author: | Hiber [ May 11th, 2010, 5:29 ] |
| Post subject: | Looking to recover corrupted PSD after power failure |
My UPS has died and the PC turned off while I was working in Photoshop. After I booted back in, the PSD file is corrupt (the last 70% of the file data is now just zeros). Any way to recover the data with some advanced tool? |
| Author: | chinopk [ May 11th, 2010, 7:10 ] |
| Post subject: | Re: Looking to recover corrupted PSD after power failure |
may be you should look for *.tmp file in the same folder and renaming it to *.psd will help, not sure but worth to try. |
| Author: | Hiber [ May 11th, 2010, 16:49 ] |
PS doesn't store tmp unfortunately. |
| Author: | BlackST [ May 13th, 2010, 8:02 ] |
Then maybe last resort was pagefile assuming you could "freeze" the HDD (no, not putting it with the ice cream etc.) and maybe even not . Otherwise, a lot of job to do again :S |
| Author: | craig6928 [ May 14th, 2010, 10:04 ] |
that sods law that as your hard drive was writing and it went down not much you can do unless you might try system restore and hope windows backed this file up |
| Author: | chinopk [ May 16th, 2010, 6:58 ] |
windows restore only modify system files, it has nothing to do with other files you created or deleted |
| Author: | craig6928 [ May 16th, 2010, 19:33 ] |
if the file system restore possible the temp file would had been restore allso |
| Author: | hdd_01 [ May 16th, 2010, 23:59 ] |
Try this. determine the locations where the file was being written. this can be, your personal folder i.e. documents/photoshop/ and/or photoshop working folder , possibly ps folder at programs files. On those directories, run some DEEP recovery software scan, dont scan just for *.psd but for any file. This could* show some iteration of your file, at some point. try looking for the file sizes in the results, and recover those files that near your *.psd file size or are close to narrow results. By this same process, you could try to recover the virtual memory that photoshop was using at the time the system went down. So DONT run photoshop again, and run file recovery on the drive and hopefully place where photoshop stores its virtual memory. Once you recover the virtual memory file ( bigger than 250MB file possibly), i have no idea what you can do. Maybe search the binary for a pattern taken form your partial save (and hex digit sequence...), and try to find and extract the file in the virtual cache.. but that must be harder than voodoo. good luck. |
