| hdd low level format tool for seagate http://forum.hddguru.com/viewtopic.php?f=7&t=16085 |
Page 1 of 1 |
| Author: | diezjackdaniels [ June 14th, 2010, 5:00 ] |
| Post subject: | hdd low level format tool for seagate |
Hello, i have a big problem in a seagate hard disk, is a barracuda model, i try to use seagate seatols zero fill, but still problems. In my desesperation i look in google and i discover hdd low level format tool program. A lot of people talk very good for this program. My question is if hdd low level format tool is similar like seatools zero fill or is different and obviusly better to try to recorver my hard disk?? Thanks |
| Author: | fzabkar [ June 14th, 2010, 20:10 ] |
| Post subject: | Re: hdd low level format tool for seagate |
What is the problem with your drive? Bad blocks? |
| Author: | poehere [ June 15th, 2010, 0:50 ] |
If you want to recover your drive and zero fill or low level format good luck on this one your data is gone. Better to recover files before doing this one. What do you think low level format or zero fill means. Excatally this one complete wipe. Good luck |
