| is my 500gb hitachi IDE hard drive defective? http://forum.hddguru.com/viewtopic.php?f=7&t=16283 |
Page 1 of 1 |
| Author: | ejames82 [ July 4th, 2010, 18:41 ] |
| Post subject: | is my 500gb hitachi IDE hard drive defective? |
somehow hitachi's own diagnostic tool won't run on their hard drive. so i ran seatools dos version and it passes the hard drive with no errors. i realize that seatools is a good tester, but doesn't really scrutinize the hard drive in the way i feel good about. i scanned with MHDD and it says this in the right hand column: 3ms--3623593 10ms--196386 50ms--10451 150ms--44 <500ms--4 >500ms--6 i also received warnings at the lower right hand corner: 302165565 314532810 317405895 318910650 318917790 821472555 does this data say that the hard drive is faulty? could someone who is knowledgeable about MHDD please answer this question? thanks. |
| Author: | fzabkar [ July 7th, 2010, 3:14 ] |
| Post subject: | Re: is my 500gb hitachi IDE hard drive defective? |
ejames82 wrote: I scanned with MHDD and it says this in the right hand column: 3ms--3623593 10ms--196386 50ms--10451 150ms--44 <500ms--4 >500ms--6 I also received warnings at the lower right hand corner: 302165565 314532810 317405895 318910650 318917790 821472555 Does this data say that the hard drive is faulty? ISTM that there are 6 very weak groups of sectors, mostly around the 150GB mark, that require several retries. If they become problematic, then you could possibly exclude them by placing them inside a small, empty partition. |
| Author: | ejames82 [ July 7th, 2010, 10:53 ] |
fzabkar, it's good to know i have that option. unfortunately, i keep getting a grub error 17 with this hard drive. i think there is an error on a critical area of the hard drive (mbr, boot files, or grub). i keep getting error 17's. it's now happened four times. i will reinstall linux with a program called 'remastersys' and not long later, another error 17. this is a relatively new hard drive, so i think i will return it for replacement. thanks. |
| Author: | lcoughey [ July 7th, 2010, 11:07 ] |
I recommend you rescan the drive and see if the same sectors are reported with warnings. |
| Author: | poehere [ July 7th, 2010, 14:06 ] |
RMA the HDD it is better for you on this one. If your install gives this error not too long after installing your OS then it is better to change out your HDD. Happens. |
| Author: | ejames82 [ July 8th, 2010, 9:24 ] |
Icoughey, "I recommend you rescan the drive and see if the same sectors are reported with warnings." same sectors are reported with warnings? it didn't appear that this info was available. how can i obtain/investigate this? poehere, that's probably the way i'm going to go anyway. but a chance to learn how to better use and understand this tool would be beneficial to me. the tool won't show me anything on a good hard drive, only a bad one. thanks for the replies. |
