| what a good program to do image of the hard drive http://forum.hddguru.com/viewtopic.php?f=7&t=16434 |
Page 1 of 1 |
| Author: | craig6928 [ July 20th, 2010, 3:19 ] |
| Post subject: | what a good program to do image of the hard drive |
im looking for a good program where i can image the whole hard drive of my arcade machines so when it does go down i got a backup image i can reload can anyone tell me of a easy program to do imaging with i got 4 arcade machines and they both run of windows so i like to do a image and keep them on the same drive cheers |
| Author: | einstein9 [ July 20th, 2010, 5:25 ] |
| Post subject: | Re: what a good program to do image of the hard drive |
well for normal HD Image i use Ghost but for the arcade i tried it sometimes ghost does not do proper job which i dono why anyway, i tried this : Acronis® True Image works perfect for ur case, remember after making HD Image, try it after, the cloned one to make sure all OK also, some arcade machines restrict the appz inside with the HD Vol SN. which can be edited with other tools thats all |
| Author: | granaryloaf [ July 20th, 2010, 6:53 ] |
DD? Its free |
| Author: | neuron [ July 22nd, 2010, 10:01 ] |
Hi, ddrescue in Linux, BSD and MacOSX. http://ftp.gnu.org/gnu/ddrescue Best regards, Neuron |
| Author: | lcoughey [ July 23rd, 2010, 10:38 ] |
Use your data compass. |
| Author: | code_slave [ July 23rd, 2010, 20:10 ] |
dd use a program that 'bit copies' with no regard for the underlying structure of the drive or allocation tables. |
| Author: | granaryloaf [ July 27th, 2010, 8:05 ] |
lcoughey wrote: Use your data compass. Well you can try, there is a 1 in 10 chance it will do the job without crashing. |
| Author: | digitalrecoveryNZ [ July 27th, 2010, 9:06 ] |
I agree with Neuron, either DDrescue or another called hddup (hdd duplicate) the latter is not free though. |
| Author: | craig6928 [ August 2nd, 2010, 0:44 ] |
thanks for the information guys i used both programs before was seeing if any other good ones out there in the world wide web cheers
| Author: | laptokowiec [ August 2nd, 2010, 5:40 ] |
You can try DMDE. |
