| MHDD errors http://forum.hddguru.com/viewtopic.php?f=7&t=16496 |
Page 1 of 1 |
| Author: | Wassy [ July 26th, 2010, 18:15 ] |
| Post subject: | MHDD errors |
Im really trying to learn MHDD and use at as a reliable diagnostic tool, but I must admit I'm really struggling to find out what the error codes mean. I have tried searching the internet for some of them, and even tried searching the forums but havent found any list that shows what the codes mean. Or is there a way MHDD tells you and I just dont know? |
| Author: | xsoliman [ July 27th, 2010, 7:52 ] |
| Post subject: | Re: MHDD errors |
What error codes in particular ? Or do you mean the UNC ABRT abort IDNF AMNF TONF BBK I'm not exactly sure what they are also. but they arent good (unless theres only a few of them) Used to know what a few of them were, but forgotten |
| Author: | fzabkar [ August 18th, 2010, 1:59 ] |
See page 7 of this DeepSpar white paper: http://www.deepspar.com/pdf/DeepSparDis ... paper3.pdf |
| Author: | rzr [ December 26th, 2010, 20:41 ] |
can IDNF errors (on wdc) be fixed using a fw replacement or any software operation ? regards |
| Author: | VistaViewer [ January 4th, 2011, 20:11 ] |
I just discovered MHDD today, and I'm trying to use it to diagnose a problem Seagate ST31500341AS SATA drive that keeps dropping offline in a RAID system. It works OK when attached in a single-drive configuration. This make/model drive is causing a lot of problems for many users, and Seagate has issued some firmware updates. Mine is not on this of those with the problem firmware, yet the drive is definately having a problem. I am running on a dual Xeon ASUS Z8NA-D6 mobo. This is a very late design running the latest Intel CPUs. I get the following errors when I boot MHDD from CDROM: MHDD PCI Scan module v3.2 PCI Bus ver: 3.0 PCI Last Bus: 10 An unhandled exception occurred at 0x00036350 : ERRORRANGE : Range Check Error 0x00036350 0x0002CE51 0x0031C0D4 Anyone have any idea what this means? It doesn't look like MHDD is going to help me with my problem today. VV |
| Author: | drc [ January 4th, 2011, 20:14 ] |
Looks like it is not happy with your hardware config. Try a different computer, or if this is not the system that the RAID is set up on, try changing it to IDE / ATA / Legacy mode in the BIOS |
