 Post subject: Any softwares for unllocated GPT partion recovery?
PostPosted: August 14th, 2010, 14:34
Hi All Gurus,
I have a Seagate Barracuda 7200.10 750GB hdd that was used for 64 bit Windows 7. Now it cannot be accessed. It can be cloned so there no fw or head issues. Under Win XP's disk management, it shows as GPT Protective Partition. In 64 bit Win 7, it is unallocated. Tried using varous data recovery softwares with no luck---no data at all. Any software can get back the lost volume and data? Any suggestions would be highly appreciated.
Thanks.
 Post subject: Re: Any softwares for unllocated GPT partion recovery?
PostPosted: August 16th, 2010, 6:37
Well there should still be a normal NTFS (or FAT/FAT32) data partition on the drive unless something catastropic has happened.
This partition will be a bit further into the drive than a standrad MBR disk
But a scan of the drive from the start should have found it
PostPosted: August 16th, 2010, 8:49
Did you try someof the software mentioned on the 'software' link on the main hddguru page?
Or Hirens CD has something like Getdataback NTFS; NTSF Mount and some other wierd stuff---that works quite well if drive is ok.
Otherwise you may have a critical problem with the drive itself
Free Solutions
PostPosted: October 18th, 2010, 2:35
The filesystem is same with DOS partition so you could recover all the partition like DOS partition.
Data Extractor Free Lab
Disk firware repair,Data Extractor, Mobile Recovery,USB/SD Monolith Recovery Tool&Services
skype:peter.zyo
Users browsing this forum: No registered users and 58 guests
