| join ddrescue images http://forum.hddguru.com/viewtopic.php?f=7&t=16918 |
Page 1 of 1 |
| Author: | Wassy [ September 4th, 2010, 22:21 ] |
| Post subject: | join ddrescue images |
K so basically I was doing a heavy ddrescue image of a drive that was taking about a month to get done. The sad part is that about 20% through the recovery we lost power at my place of work |
| Author: | dobrevjetser [ September 5th, 2010, 13:41 ] |
| Post subject: | Re: join ddrescue images |
If These are binary images, you have to find where they coincide. Then you can join them using a hex editor like winhex. |
| Author: | drc [ September 5th, 2010, 16:42 ] |
copy /b |
| Author: | Wassy [ September 5th, 2010, 21:52 ] |
So with the copy /b will that have any issues with the first started image? I really wish I remember what the error was that got this all started, but do you think it will still just simply combine them? I will give it a try on Tuesday since its labor day tomorrow. |
| Author: | drc [ September 5th, 2010, 22:38 ] |
It sounds like you are saying you have multiple different pieces of the image that you need to assemble. You can do that with copy, as long as there are not any sectors missing or overlapped |
| Author: | enderst [ September 7th, 2010, 0:08 ] |
in linux use 'cat drive.img drive1.img > fulldrive.img' |
| Author: | Wassy [ September 10th, 2010, 17:10 ] |
You are the bomb!! that worked great |
| Author: | N.C. [ September 12th, 2010, 13:02 ] |
ddrescue can do this as well. (more precise way do solve this problem) Janos |
