| Problems when installing Media Tools Proffesional - ERROR http://forum.hddguru.com/viewtopic.php?f=7&t=17104 |
Page 1 of 1 |
| Author: | wallstreet [ September 22nd, 2010, 9:59 ] |
| Post subject: | Problems when installing Media Tools Proffesional - ERROR |
When trying to install I get error : "Failed to communicate with CD-burning engine" I have issues burning CDR discs, though DVDs work fine,.. this a known issue ive had for long though.. btw the driver is a NEC 3520-A |
| Author: | einstein9 [ September 22nd, 2010, 11:45 ] |
| Post subject: | Re: Problems when installing Media Tools Proffesional - ERROR |
chk the following service working? IMAPI CD-Burning COM Service and did u try : - another Blank CD Brand? - update dvdrw FW try: http://forum.rpc1.org/portal.php - try another recorder |
| Author: | wallstreet [ September 22nd, 2010, 14:20 ] |
Einstain9, thx for the reply m8. Ive just restarted the service and that did not work, yes it is running. Another blank CD ive tried too (its not been working for quite some time I recall) I just updated my FW with the same version I already had, the latest one from the official website. Im trying to fix this recorder as I have no other at my disposal at this moment :=( Any other ideas? |
| Author: | Steve [ September 22nd, 2010, 15:05 ] |
wallstreet wrote: Any other ideas? Write it to a floppy disk |
| Author: | wallstreet [ September 22nd, 2010, 15:28 ] |
I dont have a floppy disk lol... I tried burning again just to get the logfile from nero : ---------------------------------------------------------------------------------------------------------------- 1C82-0000-19E5-MAAX-4001-4643-**** Windows XP 5.1 IA32 WinAspi: - NT-SPTI used Nero Version: 7.10.1.0 Internal Version: 7, 10, 1, 0 Recorder: <_NEC DVD_RW ND-3520AW> Version: 3.07 - HA 1 TA 0 - 7.10.1.0 Adapter driver: <IDE> HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: <HGN J8HAFS5Q >Version: 1.03 - HA 1 TA 1 - 7.10.1.0 Adapter driver: <IDE> HA 1 === Scsi-Device-Map === DiskPeripheral : ST3320620AS atapi Port 1 ID 1 DMA: On DiskPeripheral : WDC WD6400AAKS-00A7B2 atapi Port 2 ID 0 DMA: On CdRomPeripheral : _NEC DVD_RW ND-3520AW atapi Port 3 ID 0 DMA: On CdRomPeripheral : HGN J8HAFS5Q 1.03 aetngl17 Port 4 ID 0 DMA: Off === CDRom-Device-Map === _NEC DVD_RW ND-3520AW F: CdRom0 HGN J8HAFS5Q G: CdRom1 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte BUFE : 0 Physical memory : 2047MB (2097151kB) Free physical memory: 2047MB (2097151kB) Memory in use : 22 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 22.9.2010 CD-ROM (ISO) 8:54:23 PM #1 Text 0 File SCSIPTICommands.cpp, Line 424 LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL 8:54:23 PM #2 Text 0 File Isodoc.cpp, Line 6666 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 8:54:23 PM #3 Text 0 File Burncd.cpp, Line 3196 _NEC DVD_RW ND-3520AW Buffer underrun protection activated 8:54:23 PM #4 ISO9660GEN -11 File Geniso.cpp, Line 3343 First writeable address = 0 (0x00000000) 8:54:23 PM #5 Text 0 File Burncd.cpp, Line 3508 Turn on Disc-At-Once, using CD-R/RW media 8:54:24 PM #6 Text 0 File DlgWaitCD.cpp, Line 307 Last possible write address on media: 359848 ( 79:59.73) Last address to be written: 88724 ( 19:44.74) 8:54:24 PM #7 Text 0 File DlgWaitCD.cpp, Line 319 Write in overburning mode: NO (enabled: CD) 8:54:24 PM #8 Text 0 File DlgWaitCD.cpp, Line 2972 Recorder: _NEC DVD_RW ND-3520AW; CDR code: 00 97 17 06; OSJ entry from: Moser Baer India Limited ATIP Data: Special Info [hex] 1: D0 00 A0, 2: 61 11 06 (LI 97:17.06), 3: 4F 3B 4A (LO 79:59.74) Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid) 8:54:24 PM #9 Text 0 File DlgWaitCD.cpp, Line 493 >>> Protocol of DlgWaitCD activities: <<< ========================================= 8:54:24 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 793 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 88725 (88725) = #88725/19:43.0 relocatable, disc pos for caching/writing not required/ required -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 88725 blocks [F: _NEC DVD_RW ND-3520AW] -------------------------------------------------------------- 8:54:24 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 995 Prepare [F: _NEC DVD_RW ND-3520AW] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: Idx 0 Idx 1 Next Trk 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 182016000, ISRC "" DAO layout: =========== ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________ -150 | lead-in | 0 | 0x41 | 0 | 0 | 0x00 -150 | 1 | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 1 | 0x41 | 88725 | 0 | 0x00 88725 | lead-out | 1 | 0x41 | 0 | 0 | 0x00 8:54:24 PM #12 Text 0 File SCSIPTICommands.cpp, Line 215 SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME 8:54:24 PM #13 Text 0 File Burncd.cpp, Line 4294 Caching options: cache CDRom or Network-Yes, small files-No (<64KB) 8:54:24 PM #14 Phase 24 File dlgbrnst.cpp, Line 1762 Caching of files started 8:54:24 PM #15 Text 0 File Burncd.cpp, Line 4413 Cache writing successful. 8:54:24 PM #16 Phase 25 File dlgbrnst.cpp, Line 1762 Caching of files completed 8:54:24 PM #17 Phase 36 File dlgbrnst.cpp, Line 1762 Burn process started at 32x (4,800 KB/s) 8:54:24 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2721 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 8:54:24 PM #19 Text 0 File MMC.cpp, Line 17687 StartDAO : CD-Text - Off 8:54:24 PM #20 Text 0 File MMC.cpp, Line 22363 Set BUFE: Buffer underrun protection -> ON 8:54:24 PM #21 Text 0 File MMC.cpp, Line 17915 CueData, Len=32 41 00 00 14 00 00 00 00 41 01 00 10 00 00 00 00 41 01 01 10 00 00 02 00 41 aa 01 14 00 13 2d 00 8:54:24 PM #22 Text 0 File ThreadedTransfer.cpp, Line 269 Pipe memory size 83836800 8:54:33 PM #23 SPTI -1106 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x03 CDB Data: 0x2A 00 FF FF FF 6A 00 00 20 00 00 00 Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 73 03 Buffer x069d0ec0: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8:54:33 PM #24 CDR -1106 File Writer.cpp, Line 303 Power calibration error F: _NEC DVD_RW ND-3520AW 8:54:34 PM #25 Phase 38 File dlgbrnst.cpp, Line 1762 Burn process failed at 32x (4,800 KB/s) 8:54:34 PM #26 Text 0 File SCSIPTICommands.cpp, Line 261 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 8:54:39 PM #27 Text 0 File Cdrdrv.cpp, Line 11185 DriveLocker: UnLockVolume completed 8:54:39 PM #28 Text 0 File SCSIPTICommands.cpp, Line 424 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL Existing drivers: Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) |
| Author: | wallstreet [ September 22nd, 2010, 17:30 ] |
I solved it, something wrong with my CD burner, I used my laptops CD burner.. ye dont ask ... what a moron I was |
