| HDDScan for Windows http://forum.hddguru.com/viewtopic.php?f=7&t=17206 |
Page 1 of 1 |
| Author: | ppumkin [ October 1st, 2010, 6:11 ] |
| Post subject: | HDDScan for Windows |
Hello - I am not sure if Artyom Rubtsov is directly related to hddguru. I just have a suggestion to his nice software hddscan. It would be nice if the start up location of the program could be centre of screen or atleast top left corner if resolution is below 800x600. Everytime i start safe mode on a pc- it usually 640x480 and cant change the res and the scan windows is off screen. there is no way to get to it. And the proportions are a bit messed up- but at least there is an show autoscroll enabled for that which is ok i suppose. Thanks |
| Author: | drc [ October 1st, 2010, 9:25 ] |
| Post subject: | Re: HDDScan for Windows |
ppumkin wrote: Hello - I am not sure if Artyom Rubtsov is directly related to hddguru. I'm sure he'll see this |
| Author: | Doomer [ October 1st, 2010, 10:08 ] |
Hello - I am not sure if Artyom Rubtsov is directly related to hddguru. That would be me There is a file called main.ini, HDDScan creates it automatically when program starts first time. This file remembers coordinates of the main window after the first start and while you moving the window You can either delete the file and restart program or manually edit the main.ini to fix your problem |
| Author: | ppumkin [ October 1st, 2010, 10:20 ] |
Thanks Doomer. I will check that and update my live cd's Just wanted to thank you for a great program.. Use it daily several times - great stuff. |
| Author: | wallstreet [ October 1st, 2010, 19:24 ] |
199 UltraDMA CRC Error Count im getting on my HDD? Should i worry about this? |
