CopyR.DMA ignores ECC?
http://forum.hddguru.com/viewtopic.php?f=7&t=17247
Author:  mips [ October 5th, 2010, 7:08 ]
Post subject:  CopyR.DMA ignores ECC?
Does CopyR ignore ECC errors?
Reason I ask is I've been trying things like ddrescue, Media Tools Professional, HD Duplicator Demo (where you cannot select ignore ECC) to image a drive and I simply cannot get the data from the bad blocks and the programs report it as such.
CopyR however so far has read the first 10+% of the drive with zero errors. Surely it does not just ignore bad blocks & skip them, usually if there is an error it is indicated in red and the error counter increments.
I just created and image file of the imaged drive and there is a boat load of data in the image I extracted via file carving. I don't have time to scan through all 24000 files but those I have looked at seem fine.
Anyone care to comment or enlighten me?
Author:  Eleg [ October 5th, 2010, 7:30 ]
Post subject:  Re: CopyR.DMA ignores ECC?
HD Dupl got an option named "Read without check of control sum", implying a statistical analysis. As far as I understand this applies to handling of "UNC" errors.
Author:  mips [ October 5th, 2010, 8:18 ]
Yes I know that but you cannot enable that in the demo version. I'm more interested in what CopyR does.
