 Post subject: HddGuru not changing PM setting of USB WD Caviar
PostPosted: November 15th, 2010, 11:42
Hdd Guru is not changing the "PM" (Power Management) setting of my WD Caviar Drive
Drive model: WD10EADS, 1TB, on USB ext. drive.
It says 'supported' but the setting bounces to disabled each time I set something.
Attached screenshot:
 Post subject: Re: HddGuru not changing PM setting of USB WD Caviar
PostPosted: November 29th, 2010, 22:22
Bad Hdd Guru :) why are you not changing the PM ? :) haha
Hdd Guru will you please come and change mine too, seems to me that i can save some $ on the power bill ( will have more money to get drunk and stoned ) :) cool !
PostPosted: November 29th, 2010, 22:45
It's not a bug but a feature
Current PM value cannot be retrieved from a drive that's why it bounces back (even if it was set correctly)
PostPosted: December 1st, 2010, 4:43
Is this the issue that you are wanting to address?
"This firmware modifies the behavior of the drive to wait longer before positioning the heads in their park position and turning off unnecessary electronics."
wdidle3.exe download page:
http://support.wdc.com/product/download ... 13&lang=en
Does the WD10EADS work with WDIDLE?
http://forum.synology.com/enu/viewtopic ... 24&t=18011
