 Post subject: Hitachi HDP725050GLA360
PostPosted: February 3rd, 2011, 10:31
I have damaged hdd. I can access ntfs partition and i can see files on it.
Im looking for solution to get information where (in what position) my files are physical on hdd.
I need this because im using gddrescue for make a 1:1 copy. I would like use gddrescue to start only from position where my files are stored.
`--input-position=pos'
Starting position in input file, in bytes. Defaults to 0. In fill mode it refers to the original input file.
What program show me that position after selecting a file?
smart:
smartctl 5.40 2010-03-16 r3077 [i686-pc-linux-gnu] (local build)
Copyright (C) 2002-10 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family:     Hitachi Deskstar P7K500 series
Device Model:     Hitachi HDP725050GLA360
Serial Number:    GEA534RJ02L77A
Firmware Version: GM4OA5CA
User Capacity:    500,107,862,016 bytes
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   8
ATA Standard is:  ATA-8-ACS revision 4
Local Time is:    Sat Dec 25 23:19:52 2010 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: FAILED!
Drive failure expected in less than 24 hours. SAVE ALL DATA.
See vendor-specific Attribute list for failed Attributes.
General SMART Values:
Offline data collection status:  (0x84)    Offline data collection activity
                    was suspended by an interrupting command from host.
                    Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)    The previous self-test routine completed
                    without error or no self-test has ever
                    been run.
Total time to complete Offline
data collection:          (7890) seconds.
capabilities:              (0x5b) SMART execute Offline immediate.
                    Auto Offline data collection on/off support.
                    Suspend Offline collection upon new
                    command.
                    Offline surface scan supported.
                    Self-test supported.
                    No Conveyance Self-test supported.
                    Selective Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
                    Supports SMART auto save timer.
Error logging capability:        (0x01)    Error logging supported.
                    General Purpose Logging supported.
Short self-test routine
recommended polling time:      (   1) minutes.
Extended self-test routine
recommended polling time:      ( 131) minutes.
SCT capabilities:            (0x003d)    SCT Status supported.
                    SCT Error Recovery Control supported.
                    SCT Feature Control supported.
                    SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   031   031   016    Pre-fail  Always       -       1526311368
  2 Throughput_Performance  0x0005   096   096   054    Pre-fail  Offline      -       623
  3 Spin_Up_Time            0x0007   115   115   024    Pre-fail  Always       -       333 (Average 334)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       153
  5 Reallocated_Sector_Ct   0x0033   001   001   005    Pre-fail  Always   FAILING_NOW 101
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   129   129   020    Pre-fail  Offline      -       30
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       941
10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       153
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       175
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       175
194 Temperature_Celsius     0x0002   176   176   000    Old_age   Always       -       34 (Lifetime Min/Max 17/50)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       101
197 Current_Pending_Sector  0x0022   005   005   000    Old_age   Always       -       1798
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
ATA Error Count: 3852 (device log contains only the most recent five errors)
    CR = Command Register [HEX]
    FR = Features Register [HEX]
    SC = Sector Count Register [HEX]
    SN = Sector Number Register [HEX]
    CL = Cylinder Low Register [HEX]
    CH = Cylinder High Register [HEX]
    DH = Device/Head Register [HEX]
    DC = Device Command Register [HEX]
    ER = Error register [HEX]
    ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 3852 occurred at disk power-on lifetime: 941 hours (39 days + 5 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER ST SC SN CL CH DH
  40 51 08 a3 e2 33 ea  Error: UNC 8 sectors at LBA = 0x0a33e2a3 = 171172515
  Commands leading to the command that caused the error were:
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  25 d5 08 a3 e2 33 e0 00      00:09:12.200  READ DMA EXT
  25 d5 08 a3 e2 33 e0 00      00:09:07.200  READ DMA EXT
  25 d5 08 a3 e2 33 e0 00      00:09:02.200  READ DMA EXT
  25 d5 08 a3 e2 33 e0 00      00:08:57.100  READ DMA EXT
  25 d5 08 a3 e2 33 e0 00      00:08:52.100  READ DMA EXT
Error 3851 occurred at disk power-on lifetime: 940 hours (39 days + 4 hours)
  25 d5 08 a3 e2 33 e0 00      00:08:47.000  READ DMA EXT
Error 3850 occurred at disk power-on lifetime: 940 hours (39 days + 4 hours)
  25 d5 20 29 82 1b e0 00      00:08:47.000  READ DMA EXT
Error 3849 occurred at disk power-on lifetime: 940 hours (39 days + 4 hours)
  25 d5 f0 39 81 1b e0 00      00:08:47.000  READ DMA EXT
Error 3848 occurred at disk power-on lifetime: 940 hours (39 days + 4 hours)
  25 d5 f0 49 80 1b e0 00      00:08:45.300  READ DMA EXT
SMART Self-test log structure revision number 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Thank you very much for answer,
Regards.
Users browsing this forum: pepe and 23 guests
