 Post subject: MHDD makebad, I did something very stupid
PostPosted: April 17th, 2011, 15:07
Hello
First I apologize for being such an ass for what i did.
( I shouldn't attempt to fix a drive while I was under ) :D
I ran MAKEBAD utility to make UNC weak sectors, I have done it several times before, this time, I don't remember why, it just exit and return to the MHDD> prompt, so i stupidly call makebad and press enter several times and then yes.
RESULT -> the first sector of the drive now is marked UNC , hence, the driver is now dead!.
any idea of how can i revert this?, sector 1 is OK, i just make it UNC by mistake (one F%&$#/ stupid mistake you will probably leaf your ass of :D )
I was reading and couldn't find anything that clears UNC sectors, so I will try a low level format, to see if this clears this sector.
thank you
Indkt.
 Post subject: Re: MHDD makebad, I did something very stupid
PostPosted: April 18th, 2011, 1:39
Try Zero fill your Drive or MHDD Wipe Tool ..........
PostPosted: April 18th, 2011, 4:17
that will not help much
there are other ways to do this with special tools not freeware
PostPosted: April 18th, 2011, 15:05
Thank you for your reply, microsoftengineer give me the idea to do a low level format.
that did the trick and the drive is now working again
thank you
best regards
Idk
Users browsing this forum: No registered users and 127 guests
