Page 1 of 1
Hitachi HDS725050KLA360
Posted: April 25th, 2011, 16:03
by megah
I need to flash my SATA HDS725050KLA360 with new firmware. Does anyone know of a utility I can use for this (Linux / Windows is fine)
Thnx!
Re: Hitachi HDS725050KLA360
Posted: April 25th, 2011, 16:32
by thatdellguy
Why do you need to update the firmware?
Posted: April 25th, 2011, 18:53
by fzabkar
You may be able to use the --fwdownload option in hdparm.
For example, the author of this tech note has successfully upgraded the firmware on Seagate ES.2 drives using Dell MA0D firmware:
https://ata.wiki.kernel.org/index.php/Talk:Known_issuesHowever, see his warning:
http://sourceforge.net/mailarchive/foru ... ls-supportThat said, if Hitachi has made an update available, then the updater should have been packaged with it.
Posted: April 25th, 2011, 19:29
by thatdellguy
We dont even know why the person wants to update the firmware. Sometimes its wise to sit back and wait.
Posted: May 3rd, 2011, 12:51
by megah
I need to flash it so I can use it on a storevault NAS unit. Without flashing the firmware it's not recognized.
Posted: May 3rd, 2011, 17:57
by pclab
megah wrote:I need to flash it so I can use it on a storevault NAS unit. Without flashing the firmware it's not recognized.
That's odd. And another HD is recognized by the NAS?
Maybe you need to update the FW of the NAS and not of the HD.
Posted: May 4th, 2011, 13:01
by megah
No. The NAS forces you to use their own drives (same exact model) and they charge $800 for 500GB. If I can gte a tool to flash the hitachi then I can avoid this. The NAS of end of life so I really need to hitachi flashing tool to get this done
Posted: May 18th, 2011, 11:06
by Junior0409
I can see you guys are as helpful as ever.
Posted: May 18th, 2011, 11:27
by drc
megah wrote:No. The NAS forces you to use their own drives (same exact model) and they charge $800 for 500GB. If I can gte a tool to flash the hitachi then I can avoid this. The NAS of end of life so I really need to hitachi flashing tool to get this done
No such thing, this is not how hard drives work
