 Post subject: Best software to test read & write to every sector on drive?
PostPosted: June 11th, 2011, 18:30
Basically, I have a drive that was recovered, And I know chkdsk isn't enough. I used to have some old dos software I used to read and write to ever sector on the drive multiple times in order to check the drive integrity.
What's the best / latest equivalent of that?
 Post subject: Re: Best software to test read & write to every sector on drive?
PostPosted: June 12th, 2011, 6:00
HDDSCAN will do a surface scan & show you access times & how many bad sectors the drive has.
Loki
PostPosted: June 12th, 2011, 7:46
AIUI, software that runs under a multitasking OS cannot always lock a drive for its own use. Furthermore, if the CPU is performing intensive background jobs, then the access time results may be skewed.
Instead I would suggest MHDD which runs under DOS. It does essentially the same things as HDDScan, plus a whole lot more.
PostPosted: June 12th, 2011, 13:31
Thanks so much, I think it actually have have been MHDD. I looked at that earlier and it didn't look familiar but after reading the capabilities I'm thinking that had to have been the one.
PostPosted: June 12th, 2011, 14:17
That description sounds like you might be remembering SpinRite (which I wouldn't use personally).
Users browsing this forum: No registered users and 51 guests
