| hd llf tool 2.36 build 1181 error http://forum.hddguru.com/viewtopic.php?f=7&t=19563 |
Page 1 of 1 |
| Author: | jcfm [ May 30th, 2011, 12:22 ] |
| Post subject: | hd llf tool 2.36 build 1181 error |
I wave an external disk usb 40g with bad sector y have run hdd regenerator it repair some bad sector but not wall. I now running hd llf tool 2.36 build 1181 and various “format error occurred at offset ….” messages appears. 1-what that means. 2-what should y do? stop the program our let it finished. |
| Author: | Vulcan [ May 30th, 2011, 17:53 ] |
| Post subject: | Re: hd llf tool 2.36 build 1181 error |
@jcfm: A few comments below... jcfm wrote: I wave an external disk usb 40g with bad sector When a disk starts to have bad (unreadable) sectors, it may not be worth trying to fix it (and attempts to fix may not be successful, if there is an underlying fault). jcfm wrote: y have run hdd regenerator it repair some bad sector but not wall. Perhaps this was not successful, because the drive is more faulty than you thought? jcfm wrote: I now running hd llf tool 2.36 build 1181 and various “format error occurred at offset ….” messages appears. Although I have not seen "official" support for that program here, again that message suggests that the disk is reporting errors to the commands sent by llf tool. You can try using any "zero fill" or overwriting tool (Seagate Seatools, WD DLG, MHDD etc etc), if you want to try to make the disk reallocate any currently-recognised unreadable sectors. Better would be to perform a full read scan followed by a zero fill, to try to find all unreadable sectors. However, if you see errors from these programs too, then that probably means the drive really is faulty. Is all this effort really worth doing for a 40GB disk drive, which could just be reaching the end of its life and hence becoming unreliable? Do you really want to store data on this disk, if it is unreliable? It's your data so it's your choice |
| Author: | jcfm [ May 30th, 2011, 21:47 ] |
Vulcan Thanks for your help. MHDD das not recognize usb port on my pc, my disk is a Samsung can y use Seagate Seatools or WD DLG? If not what other zero fill software exist. Y don’t use this disk for storage, for that y have a 3.5 wd, is mainly for transport it’s a big pen drive. |
| Author: | pclab [ May 31st, 2011, 6:24 ] |
Boas Não consegues ligar o disco internamente a um PC? O MHDD não funciona com USB. "Hi Can't you connect the HD directly to a PC? MHDD doesn't work with USB." |
| Author: | Vulcan [ May 31st, 2011, 7:26 ] |
@jcfm: Thanks to pclab jcfm wrote: my disk is a Samsung can y use Seagate Seatools or WD DLG? Yes. As I said before, I recommend first doing a full read scan (so that the disk has a chance to detect all currently-unreadable sectors) and then do a zero fill (so that the detected unreadable sectors will then be tested by the disk and, if needed, reallocated). WD DLG is quite easy to use. jcfm wrote: Y don’t use this disk for storage, for that y have a 3.5 wd, is mainly for transport it’s a big pen drive. If you are happy to use an unreliable disk, then it's your choice. |
| Author: | jcfm [ May 31st, 2011, 10:22 ] |
pclab Boas Infelizmente não consigo ligar o disco ao pc. Vou fazer o que diz o vulcan estou a fazer um full read scan com o HDDscan e depois um zero fill com um dos softwares que ele indicou. Se tiveres mais conselhos agradeço. Muito obrigado |
| Author: | pclab [ May 31st, 2011, 10:54 ] |
Convém fazer um full scan e verificar se há muitos sectores danificados. Se houver, é muito aconselhavel esquecer esse disco, pois pode dar problemas. "It's good to do a full scan and see if it has alot of bad sectors. If so, the best thing is to bin the drive, because you can have problems with it." |
