a way to modify the firmware of the drive
http://forum.hddguru.com/viewtopic.php?f=7&t=19726
Author:  takima007 [ June 16th, 2011, 9:54 ]
Post subject:  a way to modify the firmware of the drive
a way to modify the firmware of the hard drive so it will not start unless it can validate the serial number of the motherboard to which it is attached
Author:  labtech [ June 16th, 2011, 10:06 ]
Post subject:  Re: a way to modify the firmware of the drive
I am sorry, but are you proposing or asking something? It is a bit confusing.
Author:  takima007 [ June 16th, 2011, 10:27 ]
add the number of the motherboard in thehard disk
add the number of the motherboard in thehard disk.doc [148.5 KiB]
Downloaded 711 times
Author:  rameez [ June 17th, 2011, 5:36 ]
In windows it is possible you can write a program to do this , but modifying drives firmware is not possible i think.
