| Backup of Service Area/Modules in case of future HDD fail. http://forum.hddguru.com/viewtopic.php?f=7&t=20161 |
Page 1 of 1 |
| Author: | adam [ August 1st, 2011, 17:40 ] |
| Post subject: | Backup of Service Area/Modules in case of future HDD fail. |
Hello again! This is my second question about HDDs. When reading the recovery forums I often see "you should write the valid P-List hex module there, but you don't have one" or that [i]"after changing PCB it won't work, because some unit-specific values are missing or incorrect". Moreover I have heard about bad HDD series that can overwrite Service Area or that are failing after a power failure. My questions are: 1. Is there any possiblity to make the backup of as many as possible modules in Service Area when using programs like HDDL and only standard PATA, SATA controllers + some PATA<->SATA converters? How many informations can I retrieve by such method & which modules are important to save for the future data recovery? 2. Is there any method to retrieve informations from HDD's PCB components? What is important? I am sorry if those questions are stupid/bad, but I have not found any unambiguous answer so far. I am sorry for my English in advance. Please answer me. With best wishes adam |
