Image a Raid 0 Recovery dsk to Bootable Single Drive
http://forum.hddguru.com/viewtopic.php?f=7&t=20235
Author:  buster80 [ August 10th, 2011, 10:38 ]
Post subject:  Image a Raid 0 Recovery dsk to Bootable Single Drive
2 x SAS Raid 0 Recovered fine
Clients I.T has requested an image of the complete install to try and boot the server install as It had SQL services running when it failed and some corruption may or may not have occurred.
I have a good DSK from the toplevel and I have a romantic notion that it may work.
Using r-Image to lay it back down to a single drive but it doesn't seem to let me for some reason. (greyed out)
Question, alternative to R-Image that will allow imaging back to disk from .DSK ?
Hope that made sense
thanks
andy
Author:  drc [ August 10th, 2011, 10:52 ]
Post subject:  Re: Image a Raid 0 Recovery dsk to Bootable Single Drive
Winhex
Author:  buster80 [ August 10th, 2011, 10:54 ]
good man
Author:  Alt(R-TT) [ August 11th, 2011, 4:42 ]
R-Studio's built-in Copy module.
Author:  buster80 [ August 11th, 2011, 4:51 ]
Big fan of r-studio, could you point me to this feature, I did not know it could do that
thanks
andy
Author:  Alt(R-TT) [ August 11th, 2011, 12:22 ]
Object Copy.
Open the image in R-Studio and copy it to the disk.
Author:  buster80 [ August 15th, 2011, 5:22 ]
R-studio Did its thing :)
Nice trick cheers !
andy
Author:  Nick_CT [ August 17th, 2011, 17:31 ]
R-studio is a good bit of kit
Author:  positivebit [ August 18th, 2011, 10:11 ]
hi , i have recovered sucesfully a raid 0 (2x 320GB SATA) imagined well into 2x500SATA.
by R-studio i can build the array and save all folders and files fine.
But if i put back the 2 hard drive to the pc ( the bios is setted to raid option for sata ) it show me:
NON RAID DISK.
if i simply attach the olds 320GB drives, it show correctly : DISK Members without touching anything in bios!
Any idea why it happens?
Author:  hddguy [ August 19th, 2011, 10:50 ]
What RAID controller do you use? Some controllers, like Intel Controllers as an example, identify valid mambers from Serial Numbers. Maybe this is you problem?
