| bios password removal http://forum.hddguru.com/viewtopic.php?f=7&t=20245 |
Page 1 of 1 |
| Author: | sagaermajithia [ August 11th, 2011, 8:46 ] |
| Post subject: | bios password removal |
Hello, I had a toshiba a105 satellite series whose hdd crashed so i simply bought a new seagate hdd and put it in the pc, now after just seven days the laptops motherboard goes bad and laptop just does not switch on. The new HDD that i put in has a bios password to it and when i remove the harddrive and i put it into a different laptop the same bios password does not work. What can i do to make it accept the bios password or just get rid of it? . please help. Warm regards Sagaer Majithia |
| Author: | sagaermajithia [ August 13th, 2011, 5:47 ] |
| Post subject: | Re: bios password removal |
s there no solution to this |
| Author: | loki [ August 13th, 2011, 7:38 ] |
Search for hddunlock & AFF repair Or atola.com then go the bottom of the webpage. Check to see if your drive is supported. Loki |
| Author: | falther [ August 13th, 2011, 15:57 ] |
I bet its not a bios password. You most probably set up a hdd password in the previous laptop. If it would be a bios password - this would be active only in this specific (old) laptop and not cause any trouble in the new laptop. You have a password locked hdd. Any data recovery company can help if you need your data. If data is not that important - forget the hdd and buy a new one or try the suggestion of @loki +++ |
