| MHDD and NHPA comand http://forum.hddguru.com/viewtopic.php?f=7&t=20867 |
Page 1 of 1 |
| Author: | Elect [ October 19th, 2011, 13:54 ] |
| Post subject: | MHDD and NHPA comand |
Hi, I read about SSDs loss of size that are detected in BIOS but with 0MB of size. In a forum, a guy says He used MHDD software and run NHPA command witch solved the 0MB problem. I'm trying to use it too but I can't get it to work. I'm running miniXP in a USB pen drive in a Dell mini 9 netbook. It have a Stec 8GB SSD marked as 0MB size. I've put the MHDD at the pen too and I run it, but I got a problem: It says: Primary port 1F0h is disable. To enable see MHDD.CFG Port 170h(Secondary controler) 3. [ ] Port 100h(PC-3000 board) 5. [ ] WARNING: PRIMARY CHANNEL DISABLED FOR YOUR SAFTY WARNING: SLAVE DEVICES NOT SUPPORTED Enter HDD number [3]: Well, I can't use the NHPA command if I can't select the SSD port witch I think its the Primary marked as DISABLE. As I saw that I thought, great, I just have to go to the MHDD.CFG and change the option... Bad for me... I explain.... As I copy the software to the pen I got 2 folders and 4 files. As sone as i run MHDD.exe it creates CFG folder with a MHDD.CFG file inside and LOG folder with a MHDD.LOG file inside So far so good. but as I close the MHDD.exe and open it again it wont run any more until I delete the 2 folders. If I just erase the LOG file, it seems to start but shuts the DOS window suddenly so I can see whats written on it. If I don't erase any of them I get the error: CATASTROFIC ERROR... can't create LOG file This way I can't edit the MHDD.CFG file were theres the commands: #PRIMARY_ENABLE=FALSE The one I just needed to change for "TRUE" #AUTODETECT_ENABLE=FALSE #DEVICE=3 Even I delete the folders so I can run the programa again and create my self the CFG folder with the CFG file just with the #PRIMARY_ENABLE=TRUE command, it won't run. Can some one help me enabling it so I can use the NHPA command to try to restore the SSD factory size? Best regards, Elect |
| Author: | drc [ October 19th, 2011, 14:04 ] |
| Post subject: | Re: MHDD and NHPA comand |
Better to just make a bootable dos flash drive and put MHDD on that, so that you aren't trying to run it through Windows. However, I would be very surprised if using MHDD will solve your SSD problem. |
