 Post subject: Which effect is better—MHDD or HDD Low Level Format tool?
PostPosted: November 7th, 2011, 21:58
Hello everyone, because my harddisk has bad section, so I want to use MHDD to Erase WAITs time>350ms, yesterday someone told me the HDD Low Level Format tool is better, but I know once use HDD Low Level Format tool to format harddisk, all of my data will lose, so I only want to use MHDD to Erase WAITs time>350ms (because use MHDD, my data not lose),
I have a problem: if I use MHDD the bad section erased really disappear or use HDD Low Level Format tool the bad section really disappear? Which effect is better ? Or I must use MHDD erase waits time>350ms then use HDD Low Level Format tool to format it? Thanks very much!
 Post subject: Re: Which effect is better—MHDD or HDD Low Level Format tool
PostPosted: November 7th, 2011, 23:30
Who knows the answer? Thanks!
PostPosted: November 8th, 2011, 5:29
Who could help me?Thanks!
PostPosted: November 8th, 2011, 5:41
My friend only suggestion for you is -
1) copy all data to another hard disk & send it for RMA if under warranty
2) After ensuring all data is secure , zero fill hard disk ,it may work ,if not scrap this hdd
no software can repair bad sectors as these sectors must be listed in firmware.
PostPosted: November 24th, 2011, 18:10
better you backup all of your data, before useing MHDD for repair,
if i would be yours, i would like to backup 1st then try Low level format than zero fill format :)
