 Post subject: Partitioning In DOS
PostPosted: October 5th, 2011, 2:32
October 4, 2011
Dear Forum,
I am in the process of building a new box and I am going to have
an 80 Gig HDD (until I can afford an SSD) as C: strictly for Windows 7,
and D: for my program files. I will have 2 additional HDD's in my box:
a 1.5TB Hitachi 7K3000 7200 RPM SATA 3 64MB Cache PN 0F12114 as my
storage HDD and a 2TB Hitachi 5K3000 5940 RPM SATA 3 32MB Cache
PN 0F12117 as my backup HDD. I want to pre-partition all of the HDD's
prior to installing Windows 7. After the installation I will then format
the partitions as NTFS.
I plan on making each Hitachi one big extended MS-DOS partition
and creating multiple logical drives ranging from 30 to 500 Gigs.
My question is: Considering the sizes of the Hitachis, will Magic
Boot Disk v2.0 allow me to do this pre-partitioning in DOS in a
timely manner, or can I do this faster in "Partition Magic" or
"Partition Magic type" programs?
If MBD will NOT allow me to do the pre-partitioning, do you have
a suggestion as to a "Partition Magic type" program to use?
Thanks in advance for your help.
Al_Chi
 Post subject: Re: Partitioning In DOS
PostPosted: November 19th, 2011, 6:37
It is a huge question. I need to check out the status first. I am not sure whether Partition Magic type program will work in your case or not. As of my knowledge MBD will help you to do a pre-partitioning as you think. If it will not allow, then only the question of moving to Partition Magic type program comes. Confirming anything on both these things, I need to cross check and make sure first.
hello
PostPosted: November 19th, 2011, 7:17
30 to 500 Gigs
why the hassle partitioning it this way? any specific purpose?
PostPosted: November 20th, 2011, 13:22
all programs you have mentioned are outdated. Note NTFS version difference in win7 ( NTFS v5) I suggest to use acronis disk editior . Why to boot from slower old 80 gb disk? Remember Less drives = less power consumption ,less heat generation.
PostPosted: November 24th, 2011, 18:17
well just use acronis partition magic to create what you like faster in GUI Mode, if you like just in DOS mode.
Users browsing this forum: No registered users and 21 guests
