 Post subject: Lowlevel format now drivw not recognized
PostPosted: December 22nd, 2011, 16:20
I just finshed a low level format, now after rebooting the drive is not recognized. Upon checking device manager it is there, yet don't show a "Computer" or any where else. Thanks in advance for any help
 Post subject: Re: Lowlevel format now drivw not recognized
PostPosted: December 22nd, 2011, 16:31
To help with understanding how you got to this point:
- Why were you doing the "low-level format"?
- What program did you use to do that?
This is expected. Just follow the usual instructions for whatever version of Windows you have, to create one or more partitions on that disk. Until you do that, there are no filesystems on the disk, so there are no drive letters to show under "Computer". I hope this would be explained wherever you got the suggestion to "low-level format" the disk.
PostPosted: December 22nd, 2011, 16:41
The drive was cluttered up with a lot of programs I no longer needed, I used HDD Lowlevel drive format tool 4.12. I am using Win 7 Home professional, where is this info to create these partitions. Thanks for the reply, greatly appreciated.
PostPosted: December 22nd, 2011, 16:57
Thanks for explaining, though you've done unnecessary work - there were easier ways...
I should also have mentioned that, after creating one or more partitions, you then need to format it/them. At that point you'll see one or more drive letters under "Computer".
This forum is not for Windows support. However, 2 minutes of Googling came up with these links - ignore the adverts, and then the top 2 "real" links seem to describe the correct process for Win7:
http://lmgtfy.com/?q=windows+7+create+p ... and+format
OK, good luck :)
PostPosted: December 22nd, 2011, 23:12
OK, good luck :)
Thought I' d get back to you, with your generous help I was able to restore the HD. Thanks again.
PostPosted: December 23rd, 2011, 7:55
That's good to hear, well done :) Happy holidays!
Users browsing this forum: No registered users and 106 guests
