| HDD LLF 4.25 Don't read serial number correctly http://forum.hddguru.com/viewtopic.php?f=7&t=21832 |
Page 1 of 1 |
| Author: | Paredux [ January 24th, 2012, 3:41 ] |
| Post subject: | HDD LLF 4.25 Don't read serial number correctly |
Hello, This is my first time using HDD LLF and I found a little bug (o problem), don't read correctly the serial number on SEAGATE BARRACUDA 7200.11 1,5TB, the other data is ok. THK you. Paredux PD: Excuse my bad English |
| Author: | Vulcan [ January 24th, 2012, 8:01 ] |
| Post subject: | Re: HDD LLF 4.25 Don't read serial number correctly |
I don't support the LLF tool, but if you can supply some information, then this may help to understand the situation. Can you supply a photo of the screen (or screenshot), showing the information which you are talking about? Why are you trying to LLF the drive - what is the original situation? Perhaps your drive is really not reporting its serial number correctly... |
| Author: | tweakerxp [ June 5th, 2012, 17:30 ] |
I was searching for information on this issue and came across this post. I too con confirm that the serial number does not show correctly in HDD LLF -- it is jumbled. |
| Author: | einstein9 [ June 6th, 2012, 4:35 ] |
Paredux wrote: Hello, This is my first time using HDD LLF and I found a little bug (o problem), don't read correctly the serial number on SEAGATE BARRACUDA 7200.11 1,5TB, the other data is ok. THK you. Paredux PD: Excuse my bad English r u using any sata 2 usb adapters? or directly connected? |
