| Are my chipsets just incompatible with Secure Erase tools? http://forum.hddguru.com/viewtopic.php?f=7&t=22048 |
Page 1 of 1 |
| Author: | JWCC [ February 13th, 2012, 6:05 ] |
| Post subject: | Are my chipsets just incompatible with Secure Erase tools? |
I think that this is the right forum for this. Tried on USB cable on old laptop (Dell Latitude C400) before reading that it must be directly connected. Tried on my server(GA-K8N Pro-SLI [nForce4 chipset]) until I found that my chipset apparently isn't supported. No, it's not a RAID, either. I still get the "function not implemented" or "error 40" messages in HDParm! Yes, I used a 'junk' password to work as temporary password until reboot. Tried the master password of all spaces. Still no go. Tried on new laptop(Acer AS4551-4315): 1) hot swapping or hitting enter multiple times on boot 2) dropping to a single 2GB module 3) HDD Erase 4.0 boot CD - kept crashing at the CD-ROM driver but... program isn't in DOS boot image - d'oh! - also randomly crashed earler likely due to RAM/driver/conflict issues. 4) Hiren's boot CD's DOS portion which also has HDD Erase. 5) Linux a) Everything including the HDParm wrapper. 6) MiniXP (legal for me only because I have an XP license, hehe) a) Victoria (all variations listed online + playing with options) b) Roadkill's tool c) HDDUnlock (the silly program that needs web access to protect 'secrets') d) MHDD Victoria log: Code: 01:09:46 : Starting Victoria 4.46b Freeware (12.08.2008), 1xCPU, 2294.46 MHz, Windows XP found. 01:09:54 : PCI Bus Scan... 01:09:54 : ATI/ID 439C*, BUS: 0/DEV: 20/FUN: 1 01:10:16 : PIO access enabled. Base=1F0h, Alt=3F6h 01:10:17 : Port 01F0h - drive disconnected! 01:10:20 : PCI Bus Scan... 01:10:20 : ATI/ID 439C*, BUS: 0/DEV: 20/FUN: 1 01:10:55 : - Unknown error 01:10:56 : [ATA protocol] DRQ!!! Press RESET or restart HDD! 01:10:56 : Get drive passport: Drive error! 01:10:57 : - Unknown error 01:10:58 : [ATA protocol] DRQ!!! Press RESET or restart HDD! 01:10:59 : Get drive passport: Drive error! 01:11:00 : - Unknown error 01:11:01 : [ATA protocol] DRQ!!! Press RESET or restart HDD! 01:11:01 : Security ERASE done Thinking of trying Faltool, Fakel, FJDT, FJErase, Fujitsu Explorer, Fujtool, hddl, pchdd, etc. I've also looked at the yura.projektas.lt site. Some of those look a bit more risky. It shouldn't be this hard to get low-level tools to work since game system modders have been doing it for a while. There must be something unusual about my 3 computers that prevents this from working. That or PBK&C? I'll post more information like the results of HDParm -I, later. |
| Author: | JWCC [ February 15th, 2012, 5:53 ] |
| Post subject: | Re: Are my chipsets just incompatible with Secure Erase tool |
From what I've read by searching for 'nForce' and 'Secure Erase' on Google, this is a known issue with almost all such programs when operated on AMD boards. I'm using an old Intel board that has the more compatible chipset and onboard SATA as a workaround. Oddly, the documentation on these programs makes little or no mention of this issue. For people having this problem in the future, you might want to play with the 'AHCI/IDE/RAID' options in BIOS setup. RAID most certainly won't work! Sometimes a specific SATA port will work and others won't. If in doubt, try to get a friend with an Intel board to help. This is directly related to TRIM support on SSD (Solid-state drives) in that the issue tends to exist with specific controller chips or drivers. Good luck! The laptop is an 880M chipset, by the way. Also, I'm surprised that no one knew the answer to this question. Whatever - It's answered now. |
| Author: | Vulcan [ February 15th, 2012, 9:33 ] |
JWCC wrote: Also, I'm surprised that no one knew the answer to this question. There were other reasons too, but I was waiting for you to supply the information you said you were going to do: JWCC wrote: I'll post more information like the results of HDParm -I, later. Also, FYI: JWCC wrote: For people having this problem in the future, you might want to play with the 'AHCI/IDE/RAID' options in BIOS setup. That's already mentioned in the MHDD docs - but you said you'd tried MHDD, so I thought you already knew this. The potential need to change this BIOS setting before running MHDD (and HDDErase, for example), has also been mentioned on this board many times (by me and others) Anyway, glad you've been able to solve your own question. |
| Author: | JWCC [ February 17th, 2012, 17:59 ] |
Vulcan wrote: JWCC wrote: Also, I'm surprised that no one knew the answer to this question. There were other reasons too, but I was waiting for you to supply the information you said you were going to do: JWCC wrote: I'll post more information like the results of HDParm -I, later. Also, FYI: JWCC wrote: For people having this problem in the future, you might want to play with the 'AHCI/IDE/RAID' options in BIOS setup. That's already mentioned in the MHDD docs - but you said you'd tried MHDD, so I thought you already knew this. The potential need to change this BIOS setting before running MHDD (and HDDErase, for example), has also been mentioned on this board many times (by me and others) Anyway, glad you've been able to solve your own question. The CD images UBCD or Hiren are most likely where I was trying to use MHDD from. They didn't provide a link to the manuals... I'm going to add keywords so that the first thing people find for these will give them the links to the FAQ and manuals so they don't have to ask what I did. "unsupported function not supported implemented available unimplemented error 40 incompatible chipset nVidea nForce4" should be enough! date. http://hddguru.com/software/2005.10.02- ... al.en.html hdd-faq-t5.html http://real-world-systems.com/docs/MHDD_en_manual.html Quote: IDE/SATA Controllers: Any integrated into motherboard north bridge (addresses: 0x1Fx for primary channel, 0x17x for secondary channel) AHCI controllers, however, not all - if yours is not recognized, try switching it to the IDE mode (sometimes also called Legacy Mode). This can be done in BIOS Setup. PCI UDMA boards (detected automatically): HPT, Silicon Image, Promise, ITE, ATI and so on. Even some RAID boards are supported. In this case MHDD works with each physical drive separately UDMA/RAID controllers integrated into motherboard as additional chip Quote: The FAQ doesn't mention nForce or AMD chipsets. I was pretty sure that I found a document saying that 1 of the Promise chipsets won't ever work, but maybe the fixed it. Quote: Platform and supported hardware Platform: DR-DOS , MSDOS version 6.22 included on CD image Hardware Intel Pentium or higher CPU boot device (USB, CDROM, FDD, HDD) IDE/SATA Controllers Any integrated into motherboard north bridge (addresses: 0x1Fx for primary channel, 0x17x for secondary channel) PCI UDMA boards (detected automatically): HPT, Silicon Image, Promise, ITE, ATI and so on. Some RAID boards are supported. In this case MHDD works with each physical drive separately UDMA/RAID controllers integrated into motherboard as additional chip Hard disk drives IDE or Serial-ATA drive with size bigger than 600Mbytes, i.e. LBA mode is supported in full.removed CHS code since version 2.9 IDE or Serial-ATA drive with size smaller than 8,388,607 TBytes, i.e. LBA48 mode is supported. SCSI drive with sector size 512—528 bytes Other devices Any SCSI removable media such as tape, CDROM. Maximum sector size for such devices is 4096 bytes USB and RAID is mentioned in the manuals of ALL programs. I figured that out before even trying MHDD. Even though it's probably out of warranty, I've crossed-out the last 3 characters of the serial number. Here's the dumps: hdparm -i /dev/hdd Quote: /dev/hdd: Model=ST31000333AS, FwRev=SD15, SerialNo= 5TE03*** Config={ HardSect NotMFM HdSw>15uSec Fixed DTR>10Mbs RotSpdTol>.5% } RawCHS=16383/16/63, TrkSize=0, SectSize=0, ECCbytes=4 BuffType=unknown, BuffSize=0kB, MaxMultSect=16, MultSect=off CurCHS=16383/16/63, CurSects=16514064, LBA=yes, LBAsects=268435455 IORDY=on/off, tPIO={min:120,w/IORDY:120}, tDMA={min:120,rec:120} PIO modes: pio0 pio1 pio2 pio3 pio4 DMA modes: mdma0 mdma1 mdma2 UDMA modes: udma0 udma1 udma2 udma3 udma4 udma5 *udma6 AdvancedPM=no WriteCache=enabled Drive conforms to: unknown: ATA/ATAPI-4 ATA/ATAPI-5 ATA/ATAPI-6 ATA/ATAPI-7 * signifies the current active mode hdparm -I /dev/hdd Quote: /dev/hdd: ATA device, with non-removable media Model Number: ST31000333AS Serial Number: 5TE03*** Firmware Revision: SD15 Transport: Serial Standards: Used: unknown (minor revision code 0x0029) Supported: 8 7 6 5 Likely used: 8 Configuration: Logical max current cylinders 16383 16383 heads 16 16 sectors/track 63 63 -- CHS current addressable sectors: 16514064 LBA user addressable sectors: 268435455 LBA48 user addressable sectors: 1953525168 device size with M = 1024*1024: 953869 MBytes device size with M = 1000*1000: 1000204 MBytes (1000 GB) Capabilities: LBA, IORDY(can be disabled) Queue depth: 32 Standby timer values: spec'd by Standard, no device specific minimum R/W multiple sector transfer: Max = 16 Current = ? Recommended acoustic management value: 254, current value: 0 DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6 Cycle time: min=120ns recommended=120ns PIO: pio0 pio1 pio2 pio3 pio4 Cycle time: no flow control=120ns IORDY flow control=120ns Commands/features: Enabled Supported: * SMART feature set Security Mode feature set * Power Management feature set * Write cache * Look-ahead * Host Protected Area feature set * WRITE_BUFFER command * READ_BUFFER command * DOWNLOAD_MICROCODE SET_MAX security extension * 48-bit Address feature set * Device Configuration Overlay feature set * Mandatory FLUSH_CACHE * FLUSH_CACHE_EXT * SMART error logging * SMART self-test * General Purpose Logging feature set * 64-bit World wide name * Write-Read-Verify feature set * WRITE_UNCORRECTABLE command * {READ,WRITE}_DMA_EXT_GPL commands * Segmented DOWNLOAD_MICROCODE * SATA-I signaling speed (1.5Gb/s) * SATA-II signaling speed (3.0Gb/s) * Native Command Queueing (NCQ) * Phy event counters Device-initiated interface power management * Software settings preservation * SMART Command Transport (SCT) feature set * SCT Long Sector Access (AC1) * SCT Error Recovery Control (AC3) * SCT Features Control (AC4) * SCT Data Tables (AC5) unknown 206[12] Security: Master password revision code = 65534 supported not enabled not locked not frozen not expired: security count supported: enhanced erase 176min for SECURITY ERASE UNIT. 176min for ENHANCED SECURITY ERASE UNIT. Checksum: incorrect (0x3c), expected 0xc4 Motherboard: Gigabyte K8N SLI Pro ATA Chipsets: nForce4 SLI (SATA), ITE IT8712 (PATA) SATA driver: nvata.sys 5.10.2600.0552, idecoi.dll 1.0.0.1, idecoins.dll 1.0.0.1, NVCOI.DLL 1.0.0.29 |
| Author: | JWCC [ February 18th, 2012, 0:56 ] |
I blame being tired on top of being in a hurry... Those are the lines for a 1TB drive that I'm copying over to my shiny new 2TB from WD. I got a WD20EZRX-00EWTB0 which is equivalent to WD20EARX but with AFM. Here's the list of model number info for those interested (WD Document #2579-001028-A23). Here's the legit info: hdparm -i /dev/hde Quote: /dev/hde: Model=FUJITSU MHZ2320BH G1, FwRev=00000009, SerialNo= K60AT922A*** Config={ HardSect NotMFM HdSw>15uSec Fixed DTR>10Mbs } RawCHS=16383/16/63, TrkSize=0, SectSize=0, ECCbytes=0 BuffType=DualPortCache, BuffSize=8192kB, MaxMultSect=16, MultSect=off CurCHS=16383/16/63, CurSects=16514064, LBA=yes, LBAsects=268435455 IORDY=on/off, tPIO={min:120,w/IORDY:120}, tDMA={min:120,rec:120} PIO modes: pio0 pio1 pio2 pio3 pio4 DMA modes: mdma0 mdma1 mdma2 UDMA modes: udma0 udma1 udma2 udma3 udma4 *udma5 AdvancedPM=yes: mode=0x80 (128) WriteCache=enabled Drive conforms to: unknown: ATA/ATAPI-3 ATA/ATAPI-4 ATA/ATAPI-5 ATA/ATAPI-6 AT A/ATAPI-7 * signifies the current active mode hdparm -I /dev/hde Quote: /dev/hde: ATA device, with non-removable media Model Number: FUJITSU MHZ2320BH G1 Serial Number: K60AT922A*** Firmware Revision: 00000009 Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5; Revisi on: ATA8-AST T13 Project D1697 Revision 0b Standards: Used: ATA-8-ACS revision 3f Supported: 8 7 6 5 Configuration: Logical max current cylinders 16383 16383 heads 16 16 sectors/track 63 63 -- CHS current addressable sectors: 16514064 LBA user addressable sectors: 268435455 LBA48 user addressable sectors: 625142448 device size with M = 1024*1024: 305245 MBytes device size with M = 1000*1000: 320072 MBytes (320 GB) Capabilities: LBA, IORDY(can be disabled) Queue depth: 32 Standby timer values: spec'd by Standard, no device specific minimum R/W multiple sector transfer: Max = 16 Current = 16 Advanced power management level: 128 (0x80) Recommended acoustic management value: 254, current value: 254 DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 *udma5 Cycle time: min=120ns recommended=120ns PIO: pio0 pio1 pio2 pio3 pio4 Cycle time: no flow control=120ns IORDY flow control=120ns Commands/features: Enabled Supported: * SMART feature set * Security Mode feature set * Power Management feature set * Write cache * Look-ahead Host Protected Area feature set * WRITE_BUFFER command * READ_BUFFER command * DOWNLOAD_MICROCODE * Advanced Power Management feature set SET_MAX security extension * Automatic Acoustic Management feature set * 48-bit Address feature set * Device Configuration Overlay feature set * Mandatory FLUSH_CACHE * FLUSH_CACHE_EXT * SMART error logging * SMART self-test * General Purpose Logging feature set * WRITE_{DMA|MULTIPLE}_FUA_EXT * 64-bit World wide name * IDLE_IMMEDIATE with UNLOAD unknown 119[0] * WRITE_UNCORRECTABLE command * {READ,WRITE}_DMA_EXT_GPL commands * Segmented DOWNLOAD_MICROCODE * SATA-I signaling speed (1.5Gb/s) * Native Command Queueing (NCQ) * Host-initiated interface power management * Phy event counters DMA Setup Auto-Activate optimization Device-initiated interface power management * Software settings preservation * SMART Command Transport (SCT) feature set * SCT LBA Segment Access (AC2) * SCT Error Recovery Control (AC3) * SCT Features Control (AC4) * SCT Data Tables (AC5) Security: Master password revision code = 65534 supported enabled locked not frozen not expired: security count not supported: enhanced erase Security level high 320min for SECURITY ERASE UNIT. Checksum: incorrect (0x1c), expected 0xe4 |
| Author: | Vulcan [ February 18th, 2012, 11:23 ] |
Are you asking a question? If so, I didn't see one (although other readers might have seen one that I missed). Or are you just providing the info which you said you were going to do, but since you've solved your issue, you're not expecting a reply? |
| Author: | JWCC [ March 10th, 2012, 22:28 ] |
It was followup info since I've still not got an Intel board. I'm just going to take it back if I can't solve this before exchange warranty runs out. Yeah, I saved the receipt, hehe. I'm looking for a (hopefully) cheap PCI card that supports HDDErase or the like. I'll probably return it or get a compatible card (which can be used again for other drives, of course) and follow up. |
| Author: | JWCC [ March 11th, 2012, 18:34 ] |
PCI-based Sil3112 work? Or VT6421a? Not too many cards advertise if they support AHCI. These can be flashed with non-RAID firmware that turns them into IDE ports. |
| Author: | JWCC [ March 15th, 2012, 1:30 ] |
The Sil3531ACNU used in a StarTech PEXESATA1 is PCI-E. The program manual doesn't say exactly what chipsets to get so I'm asking if anyone has tested these. Is there some changelist/history for hardware/firmware support? I do know that there are also often 2 versions of the firmware - 'fake' RAID and straight SATA (nonRAID). Which of these work? Sil3112? Sil3114? Sil3124? Sil3132? Sil3512? Sil3531? |
