Change WD,Seaget Serial Software
http://forum.hddguru.com/viewtopic.php?f=7&t=22395
Page 1 of 3
Author:  flykiller [ March 16th, 2012, 13:45 ]
Post subject:  Change WD,Seaget Serial Software
Sorry ! My English is very poor.
This is a software used to change WD(Royl),Seaget(11.12) serial and model (Because it is only for their own use,so
there is no documentation) Share it now !
Need micorsoft .net 4.0
HDSerial.rar [2.82 MiB]
Downloaded 7169 times
Author:  guru [ March 16th, 2012, 14:31 ]
Post subject:  Re: Change WD,Seaget Serial Software
you better scan that well for Virus :idea:
Author:  Doomer [ March 16th, 2012, 15:19 ]
I'm wondering where did you get these constants: eReadSingleCopy, eReturnFileInfo, etc.
Author:  flykiller [ March 16th, 2012, 15:22 ]
:?: :?: What error
Author:  flykiller [ March 16th, 2012, 15:35 ]
This program is written by me ,and also be recompiled!
So,There is another program is used to lock/unlock WD Hard disk "PUIS"!
PUIS.rar [12.55 KiB]
Downloaded 1506 times
Author:  Doomer [ March 16th, 2012, 15:42 ]
flykiller wrote:
:?: :?: What error
it is not an error
it's part of your source code in the vsc file
Author:  Doomer [ March 16th, 2012, 15:43 ]
Also, looks kinda doubtful that it's gonna work for Seagates
Author:  flykiller [ March 16th, 2012, 15:52 ]
Doomer wrote:
flykiller wrote:
:?: :?: What error
it is not an error
Haha,,I think ,I want the program to encrypt :lol:
Author:  Doomer [ March 16th, 2012, 15:56 ]
encryption is always good :mrgreen:
So, where did you get those constants?
Author:  flykiller [ March 16th, 2012, 16:16 ]
This program is a function of another program.Therefore ,no encryption.
Part from WD Trex program.Partly from my own research.
Author:  fzabkar [ March 16th, 2012, 16:18 ]
https://www.virustotal.com/file/07a3153 ... 331928943/
SHA256: 07a3153ad804869a1bcce73e8acc72411001baf4d347c9c424dca6f0c1c3af2c
File name: HDSerial.rar
Detection ratio: 0 / 43
Analysis date: 2012-03-16 20:15:43 UTC
Author:  fzabkar [ March 16th, 2012, 16:21 ]
https://www.virustotal.com/file/9404390 ... 331929202/
SHA256: 9404390600e730ba7be3c6f24c88eec0df5aad842f8f49a5f0530db58ddc5b46
File name: PUIS.rar
Analysis date: 2012-03-16 20:20:02 UTC
Author:  Doomer [ March 16th, 2012, 16:21 ]
Cool, thanks for answering
Author:  fzabkar [ March 16th, 2012, 16:24 ]
Looking forward to more ...
Thanks in advance. ;-)
Author:  flykiller [ March 16th, 2012, 22:35 ]
Carefully ,Flashed ROM there is great risk of the operation!
flash.rar [27.25 KiB]
Downloaded 1284 times
Author:  flykiller [ March 16th, 2012, 23:49 ]
Note! This program must be in the same directory and hdserial program!
Author:  guru [ March 17th, 2012, 4:54 ]
What part is from
you own research?
Author:  flykiller [ March 17th, 2012, 5:12 ]
guru wrote:
What part is from
you own research?
tv
Part of my main program!
Yes
Author:  flykiller [ March 17th, 2012, 5:15 ]
For Seagate:
If click "get" button can not be displayed serial number. You need to do the following steps:
1. Find serial number offset address
- run terminal program ,connect hd.
In F3>B921600 reset terminal program baudrate to 921600.in terminal program click transfer menu select capture txt.
In F3>/1B0,0,200,1.stop capture,and open capture.txt ,find 53 54
2. Set offset address
To find the correct offset address, respectively, fill in the text box in the lower right corner 。click "set" button.
3. Try to get serial sn
If you find the correct offset address, click "get" button ,it will display the correct information.
For wd:
some of the new model HDD, the model on the flash inside。
Author:  guru [ March 17th, 2012, 7:40 ]
I don't agree with changing serial numbers as it's connected to fraud most of the time :idea:
Page 1 of 3 All times are UTC - 5 hours [ DST ]
