 Post subject: Contribution - Script to sort testdisk/photorec results
PostPosted: May 12th, 2012, 17:22
Hi all,
Those of you using testdisk/photorec free software for recovering lost files shall know what means searching specific file types as images in results.
I just did a short python script that sorts all the files extracted by testdisk/photorec in folders sorted by filetype (images, pdf, video, etc).
You can check it too in my website at http://system-tricks.com/index.php/data ... y-results/
Hope you find it useful.
#!/usr/bin/env python
import os, magic
from shutil import copyfile
#================ CONFIG SECTION ================#
# Source folder with photorec/testdisk results:
testdisk_results = 'SOURCE FOLDER WHERE TESTDISK RESULTS ARE'
# Destination folder where you want to store the sorted results:
base_destdir = 'DESTINATION FOLDER WHERE YOU WANT TO STORE SORTED RESULTS'
# File types to filter out. You can add every MIME-types you are not interested on:
filter = ['application_octet-stream', 'text_plain']
#============= END OF CONFIG SECTION ============#
types = {}
mime = magic.open(magic.MAGIC_MIME)
mime.load()
for dir in os.listdir(testdisk_results):
    for filename in os.listdir(os.path.join(testdisk_results, dir)):
        file = os.path.join(testdisk_results, dir, filename)
        filetype = mime.file(file).split(';')[0].replace('/', '_').replace(" ", "_").split(',')[0]
        if filetype in filter:
            continue
        if not filetype in types:
            types[filetype] = 1
        else:
            types[filetype] += 1
        print filename + ": " + filetype
        destdir = os.path.join(base_destdir, filetype)
        destfile = os.path.join(destdir, filename)
        if os.path.exists(destdir):
            try:
                copyfile(file, destfile)
            except Exception, e:
                print "Error copying " + filename + ": " + str(e)
                continue
        else:
            os.makedirs(destdir)
            try:
                continue
print "\n** Results:\n--------------------"
for type in types:
    print type + ": " + str(types[type]) + " files"
print print "\n---------------------------\n\n* Finished. Results stored in " + base_destdir + "\n\n"
Users browsing this forum: Bing [Bot] and 51 guests
