Scan USB Drives in DOS with MHDD
Posted: July 6th, 2012, 3:48
by michael chiklis
i want to know if is possible to scan usb drives in dos with mhdd.
I know there are many software that can scan drives in dos, but most of them will scan only if the drive is connected via PATA or SATA port.
Some drives have an integrated sata/usb adapter so it's impossible to check those in dos, so is important to make ricognize this usb drive in dos with mhdd.
How can i do? :?
Re: Scan USB Drives in DOS with MHDD
Posted: July 6th, 2012, 5:05
by hddguy
Convert to SATA interface and check that way. Or else use Victoria in windows
Posted: July 6th, 2012, 6:04
by Mapel Jenny
There are several ways.Techies are getting their USB C Drom, Hard Drives, and other drives to work in DOS. One is using what's known as DUSE driver system. The second method is using what looks somewhat like standard C Drom driver files and a USB driver. Both methods appear to require loading an us baspiX.sys file first in config.sys in most cases. The third method is a bootdisk from a USB vendor.
Posted: July 6th, 2012, 13:53
by michael chiklis
hddguy wrote:Convert to SATA interface and check that way. Or else use Victoria in windows
How do i convert to SATA interface my WD5000BMVU 2,5" hdd?
Look the pcb connection:
Posted: July 9th, 2012, 3:51
by hddguy
PCB code is 701635 ?
Try use SATA PCB 701572 (Mercury) and restore ROM from SA.
Posted: July 9th, 2012, 4:30
by laptokowiec
There's an ISO to burn with MHDD where after installing you can choose running dos with USB drivers.
Posted: July 10th, 2012, 12:01
by michael chiklis
laptokowiec wrote:There's an ISO to burn with MHDD where after installing you can choose running dos with USB drivers.
If you mean "Magic Boot Disk 2.0" i already tried it, but doesn't work for me.
I don't know way :?:
Posted: July 11th, 2012, 3:45
by laptokowiec
So you have to mount USBASPI.SYS
Posted: July 11th, 2012, 6:36
by michael chiklis
laptokowiec wrote:So you have to mount USBASPI.SYS
How?
