HDD Raw Copy
http://forum.hddguru.com/viewtopic.php?f=7&t=23886
Author:  Brigno [ September 3rd, 2012, 4:01 ]
Post subject:  HDD Raw Copy
I try to use this beautiful SW to make a copy of a CF (with Ms-Dos o XP embedded) and works well but if I try to use a CF with a different size doesn't work perfect:
1) the finaly CF (es: 2Gb) is smollest than te source (es: 4Gb) also if the source is not all use (1.5Gb)
2) the finaly CF (es: 2Gb) is biggest than te source (es: 1Gb) at the and of the clone the final CF si 1Gb+1Gb not used
before using this software I used Norton Ghost but I prefere a portable version and ghost doesn't work with W7 64bit
What can I do ?
thank you
Brignoli Antonio
