HDD LLF being stuck
Posted: September 30th, 2012, 16:12
by godd
I am trying to format laptop Toshiba drive with known bad sectors with HDD LLF tool and it is stuck at %35. I hoped that low level format will help to mark them. Any chance I still can format this drive or should I use some other tool to get rid of bad sectors first?
Re: HDD LLF being stuck
Posted: September 30th, 2012, 20:33
by labtech
More than likely formatting will not work. Probably have a hardware failure.
How many times have you attempted to format? If more than once, did all attempts get stuck at the 35% mark?
Posted: October 3rd, 2012, 22:49
by godd
It was definitely hardware failure.... of my monitor-mounted usb port
Connected external enclosure to the back USB port of my comp and it worked this time without a hiss.
