| software to change size not partition size http://forum.hddguru.com/viewtopic.php?f=7&t=24258 |
Page 1 of 1 |
| Author: | archie [ October 16th, 2012, 22:42 ] |
| Post subject: | software to change size not partition size |
I have three identical wd 1tb drives, and I clone them as a way to backup. I would like to see at a glance a different size like 929 930 931 gb instead of all three seen as 931. I used to use a seagate drive that I changed with seatools,to report a smaller size, but wd does not have anything to do this, I even called them. Is there any easy to use program to do this? thanks |
| Author: | labtech [ October 16th, 2012, 22:44 ] |
| Post subject: | Re: software to change size not partition size |
try MHDD |
| Author: | archie [ October 16th, 2012, 22:48 ] |
I did, I was lost it said no cd rom found. I need something easy I am stupid if I have to use dos. |
| Author: | labtech [ October 16th, 2012, 23:03 ] |
archie wrote: I did, I was lost it said no cd rom found. I need something easy I am stupid if I have to use dos. Check the BIOS settings on your system. |
