HDD GURU FORUMS
http://forum.hddguru.com/
HDD Health
http://forum.hddguru.com/viewtopic.php?f=7&t=24714
Page 1 of 1
Author:  MVK [ December 13th, 2012, 14:26 ]
Post subject:  HDD Health
Hi, I would like to know what's wrong with this hard drive BIOS warned me this make a backup and replace the hard drive left aca capture SMART records, which is what I do. The disc remains stable now (Please note that English management) Thanks!
Author:  Vulcan [ December 13th, 2012, 20:12 ]
Post subject:  Re: HDD Health
Although I don't agree with everything it says, for starters read this Wikipedia article:
https://en.wikipedia.org/wiki/S.M.A.R.T.
You can see that the main concern for your drive is SMART attribute 0x01 (explained in that article). The non-zero value of attribute 0xC6 may also be giving you a hint about genuine problems, as some sectors are currently unreadable
If you have backed-up your data (which seems to be what you are saying), then now you don't need to care whether the disk deteriorates some more, or not.
Author:  MVK [ December 14th, 2012, 3:30 ]
Thank Vulcan attention, I have a backup disk, I want to know what I should do with it, the disk is stable at least in normal use copy and paste files, I recommend spending some use to check the status of it? Thank you again!
Author:  Vulcan [ December 14th, 2012, 8:35 ]
Unfortunately I don't understand exactly what you are now asking. :( No-one can predict exactly when a disk will fail, and not all disk problems result in immediate & complete failure - for example, poor performance may cause someone to decide to stop using a disk, even before there are unrecoverable read errors.
If you want to use this (likely failing) disk until it's symptoms become more obvious, then you can do that - it's your risk and your choice. :) But beware that you might get zero warning of further (perhaps catastrophic) problems - SMART is already telling you that the disk firmware believes the disk is not operating normally.
That's the best reply I can give, for the questions I think you are asking.
Author:  MVK [ December 14th, 2012, 9:53 ]
Understand that I am using a translator because I do not speak English, I am saying that that is what is wrong with this hard drive, so I read the hard disk has a parameter below the limit made ​​by the manufacturer and that there slope failure, this is so? Thank you!
Author:  Vulcan [ December 14th, 2012, 10:20 ]
Yes, I already guessed that.
MVK wrote:
this is so?
I cannot give any different answer than before, due to the problems in translation (e.g. "slope failure"?). :(
Author:  MVK [ December 14th, 2012, 12:55 ]
MVK wrote:
this is so?
Let's be more clear, I come to this forum that I can give a clear answer as in the other forums are hardware enthusiast alone, which is what is wrong with this hard drive? Indicating the rate of read errors? , Understand the question? It is advisable to change the hard drive? What would you do in this situation?
Author:  Vulcan [ December 14th, 2012, 13:27 ]
Impossible for me to answer this - the SMART information alone is not enough information. Many other factors would be part of my decision.
I have already replied (or linked to information) to your other questions, as far as I understand them. Therefore I think the language / translation / expectation problems here are too much, so I will stop and perhaps someone else will reply differently to you. Good luck!
http://www.phpbb.com/
