| software disk wiper ? with advanced options ? http://forum.hddguru.com/viewtopic.php?f=7&t=26167 |
Page 1 of 1 |
| Author: | raven4d [ June 7th, 2013, 9:27 ] |
| Post subject: | software disk wiper ? with advanced options ? |
hello , i know this might sound strange , but i need a software that can wipe some sectors every "some sectors" so if a drive have 1000000000 LBAs i want to wipe 2 sectors every 10 sectors and so on ... thank you for your help |
| Author: | lcoughey [ June 7th, 2013, 12:21 ] |
| Post subject: | Re: software disk wiper ? with advanced options ? |
Write a shell script using dd? |
| Author: | Vulcan [ June 7th, 2013, 12:28 ] |
Agreed - appropriate use of the dd "seek" parameter would seem to fit the OP's stated requirement. |
| Author: | raven4d [ June 7th, 2013, 16:15 ] |
aha , never thought of this .. i would appreciate if you can provide me with the script to use dd if=/dev/zero of=/dev/sda bs=1024 the upper command should wipe 2 sectors of the selected devise , but how to make it jump over 10 LBAs and write two zero sectors again ? adding seek=5120 ?!?! never thought of using the dd for such a task what r the flags that should be added ? thank you very much |
| Author: | raven4d [ June 8th, 2013, 4:48 ] |
#bin/sh for ((i=0 ; i<1000000000 ; i=i+10)); do dd if=/dev/zero of=/dev/sda seek=$i bs=512 count=2 ; done ; |
