Seagate Barracuda 7200.11 (HP12 firmware) locked in BSY stat
Posted: June 25th, 2013, 4:50
by Patrick
Hi
My Seagate Barracuda 7200.11 hard drive (HP12 firmware) is locked in BSY state.
I read a lot of information about how to unlock Seagate drives (with a Seagate firmware), but it seems that the procedure is different when the firwmare is HP12.
I would appreciate if you could give me the right procedure for the HP12 firmware.
Thanks in advance
Patrick
Re: Seagate Barracuda 7200.11 (HP12 firmware) locked in BSY
Posted: June 25th, 2013, 5:37
by fzabkar
Maybe this?
viewtopic.php?t=19422&p=178807#p178807If you have some electronics skill, and if you can build a simple circuit, then I may be able to help you. It should cost you about $5 in parts. Alternatively, I can help adapt something from eBay.
Posted: June 25th, 2013, 5:57
by Patrick
I have bought all the necessary material. All I need is information for unlocking a Seagate Barracuda 7200.11 hard disk with HP12 firmware.
Patrick
Posted: June 25th, 2013, 6:16
by fzabkar
According to that other thread, and assuming that the same method applies in your case, you need to inject an interference signal into the read channel. For that you need a signal generator. Your TTL RS232 adapter is something else entirely. I'm not a data recovery professional, so I don't have personal experience with this problem, but no professional is going to tell you their secret, no matter how trivial. I propose to use a 555 timer, a capacitively coupled probe, and a resistive voltage divider. Some private feedback would suggest that this procedure does indeed work, at least for the ES.2 models.
Posted: June 26th, 2013, 4:41
by Patrick
No I didn't try. I want to know the exact procedure before starting. I don't want to damage my hard disk.
Patrick
Posted: June 27th, 2013, 13:14
by Patrick
Hi
I've just connected the drive to the terminal, and the message is :
LED:000000CC FAddr:002493D1
Patrick
Posted: June 27th, 2013, 17:54
by pcimage
Do you get an "F3>" prompt if you issue "Ctrl-Z" ?
Posted: June 27th, 2013, 17:57
by Patrick
I didn't try, since when the disk is in BSY state, the terminal is locked.
Posted: June 27th, 2013, 18:14
by Patrick
Why not insulating the head contacts in the first place ?
Posted: June 28th, 2013, 0:57
by Patrick
Why is it important to power off/on the disk between the N1 and m0,2,2,0,0,0,0,22 commands ?
Some people say it isn't necessary.
Posted: July 8th, 2013, 5:36
by Patrick
Hi
I finally unlocked my hard drive and updated the firmware.
I used the standard procedure, but with the following modifications :
- I used the / and F,,22 commands after the U command
- after the N1 and / commands, powering off and on the drive locked the terminal, so I restarted the whole procedure from the beginning, without disconnecting the drive after the N1 and / commands
I then backed up my data and installed the latest firmware (HP26).
I don't know if it is the simplest procedure or if it works for other people, but it worked for me.
Posted: July 27th, 2013, 15:11
by michael chiklis
The trick to unlock terminal commands on drive with HP firmware:
http://www.overclock.net/t/457286/seaga ... -with-picsF712 and F,,22 is the trick
Posted: July 29th, 2013, 9:19
by michael chiklis
I didn't use properly the word "unlock"
What i wanted to mean was if you are stuck in terminal because commands as translator don't work you need to do CONGEN on HP 7200.11 drives.
Posted: August 21st, 2013, 1:31
by waqas_ali766
what u want to say ? i cannot understand
