smartctl reports 512 bytes Physical size for AF Disk
Posted: July 10th, 2013, 1:58
I have Toshiba MK3259GSXP Laptop HDD in my Sony laptop. Recently SMART indicated disk failure and it's likely to fail.
I booted using Linux rescue CD and ran fdisk, hdparm as well as smartctl commands.
I am bit puzzled to notice physical sector size as 512 bytes where the model number indicates Advanced Format (AF)
Even specs on Toshiba site indicate AF for this model. Here's the snapshot of smartctl.
root@sysresccd /root % smartctl --all /dev/sda
smartctl 5.42 2011-10-20 r3458 [i686-linux-3.0.13-std241-i586] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family: Toshiba 2.5" HDD MK..59GSXP (Adv. Format)
Device Model: TOSHIBA MK3259GSXP
Serial Number: 12LQC2H6T
LU WWN Device Id: 5 000039 3c3f88b29
Firmware Version: GT001H
User Capacity: 320,072,933,376 bytes [320 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Wed Jul 10 10:58:08 2013 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: FAILED!
Drive failure expected in less than 24 hours. SAVE ALL DATA.
See vendor-specific Attribute list for failed Attributes.
Could someone throw further light on this, is this HDD actually AF?
Thx.
ATA Version is: 8
Thx.
