Page 1 of 2
Samsung F1 firmware
Posted: August 2nd, 2013, 17:57
by blossio
Hi I stupdly flashed my samsung 320gb HD322HJ with Dell firmware utility.I need firmware 1AG0 (best 1AG0008) to reflash
Hope for alternative help too
Re: Samsung F1 firmware
Posted: August 4th, 2013, 2:25
by blossio
upppppp
Posted: August 4th, 2013, 7:08
by HaQue
You don't need to bump here.. If people are able to help they will
Just letting u know
Cheers
Posted: May 30th, 2016, 12:37
by balgator
I have same problem with my Samsung HD322HJ Rev A (2009.09).
After flash with DELL package is now visible like HD321HJ, but is detected by system. Anyone have fw for this drive type? Thanks for help.
Posted: May 30th, 2016, 12:38
by balgator
Any of those will be very helpfull for me:
1AC01118
1AC01113
1AG01118
1AG01113
1AC01112
1AC01110
1AC01108
1AC01117
1AC01114
Posted: May 30th, 2016, 16:03
by fzabkar
Is this the update package that you applied to your drive (Version 1AC00017, A00)?
http://downloads.dell.com/SATA/R220296.exeWhat was the original firmware version of your drive?
Posted: May 30th, 2016, 17:50
by balgator
this is exactly the update package that I have applied to my drive. HDD is detected by BIOS and Samsung utility like HD321HJ(probably 8MB cache) firmware 1AC01117. Originaly is it HD322HJ 16MB cache. I am not sure with the original firmware version, update was not planned... Is there any possibility to identify original firmware on label? ther is nothing like 1AC0/1AG0.
Posted: May 30th, 2016, 18:22
by fzabkar
The update rewrote the firmware on your PCB but did not touch the firmware in the reserved area on the platters (Maintenance Cylinders). The problem is that the firmware on the PCB must be compatible with the firmware in the MC. If you pick the wrong firmware, then you could render your drive inaccessible.
Can you read the ROM with the drive in its present state? You can obtain the demo version of SHT via this thread:
SHT v3.0.2 New:
http://www.hddoracle.com/viewtopic.php?t=1199&p=5660 How to connect a terminal cable on a Samsung drive ?
http://www.hddoracle.com/viewtopic.php? ... 189&p=2786A dump of the terminal log may help us to eliminate incompatible ROM choices (the RAM loadpoints will be incompatible).
Posted: May 31st, 2016, 12:08
by balgator
I hope that I can read the ROM. SHT software and tvicport downloaded, but i am not sure with building the terminal cable. I saw that I will need serial connection(RS232) to drive, my PC still have COM port so i dont need USB convertor. I dont saw schematics for terminal cable. Its just RX and TX (pins 2,3) from COM port to drive?
Posted: May 31st, 2016, 15:11
by balgator
I will be able to read the ROM. Ehm need I to known some offset of ROM?
But i think i will need something like this:
http://hddguru.com/articles/2005.10.01- ... schematic/ , I am right?
If you will have exactly same firmware like my original FW, which is stored in the reserved area on the platters, then have I good chance to restore my fotos?
Is there a chance for original partitions? Btw: Thank you for ur replies and help.
Posted: May 31st, 2016, 15:43
by fzabkar
Adapters based on the MAX232 chip (5V) will not be able to handle the lower LVTTL I/O voltages. Most people choose USB-TTL adapters with 3.3V I/O (which should work with your drive), but even these are inappropriate for today's 1.8V I/O.
See
http://www.hddoracle.com/viewtopic.php? ... 192&p=1779If you upload the ROM and a terminal log, then this should help us to determine compatibility. If SHT can read the firmware modules on the platters, then that would be very helpful also.
Posted: May 31st, 2016, 16:26
by balgator
I have found this one with PL2303 chip:
http://www.neven.cz/kategorie/male-spot ... l2303-cip/The output switching range is 0.4 to 2.4V for 3.3V LVTTL and 0.4 to 2.2V for 2.5V LVTTL. Can be?
Posted: June 1st, 2016, 17:41
by fzabkar
The "ds_pl2303HXD_v1_4_4.pdf" datasheet states that the VIL and VIH switching points are 0.25 x Vdd and 0.7 x Vdd for 1.8V and 2.5V supplies, and 0.3 x Vdd and 0.7 x Vdd for a 3.3V supply.
The minimum output voltage ranges are ...
0.4V - 1.25V for Vdd = 1.8V
0.4V - 1.85V for Vdd = 2.5V
0.4V - 2.4V for Vdd = 3.3V
In practice you will probably find that the actual specs are much better than these guaranteed minima, but you shouldn't count on it.
BTW, be aware that there are clones of the Prolific chip. Prolific's latest drivers will refuse to work with these clones.
Posted: June 3rd, 2016, 20:38
by balgator
Hi , i was able to read ROM and content of service area on the platter, MCF file/modules and ROM file are here:
https://www.dropbox.com/s/0jowc19lldksz ... J.rar?dl=0I hope that are files what you will need to identify original fw. Could u check it and let me know? Thank you.
Posted: June 4th, 2016, 4:17
by fzabkar
I was hoping to be able to match the MOVLY001 SA module to a suitable donor ROM, but this module is empty. I wonder if the demo version of SHT is crippled in this area???
Perhaps you could look for firmware resources that match "1AC28yrB.d11", or maybe some kind soul could help you with same.
I did have a look in the HDD Guru files area, but I didn't find anything.
Here are excerpts from the FSI and BI_RESLT modules:
- Code:
00000000 46 53 49 20 20 20 20 20 00 00 01 00 00 00 00 00 FSI ........
00000010 0A 00 00 00 54 46 31 30 30 52 31 30 30 2E 32 30 ....TF100R100.20
00000020 00 00 46 54 72 65 76 30 30 30 00 00 00 00 00 00 ..FTrev000......
00000030 00 00 31 41 43 32 38 79 72 42 2E 64 31 31 00 00 ..1AC28yrB.d11..
00000040 00 00 53 41 4D 53 55 4E 47 20 48 44 33 32 32 48 ..SAMSUNG HD322H
00000050 4A 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 J ..............
- Code:
00000000 42 49 5F 52 45 53 4C 54 09 00 01 00 00 00 00 00 BI_RESLT........
00000010 00 00 FE 00 CF 00 00 00 00 00 00 00 00 00 00 00 ..þ.Ï...........
00000020 00 00 31 41 43 32 38 79 72 42 2E 64 31 31 00 00 ..1AC28yrB.d11..
00000120 00 00 00 00 00 00 00 00 53 50 53 54 57 5F 44 41 ........SPSTW_DA
00000130 00 00 00 00 00 00 00 00 4E 05 00 00 00 00 00 00 ........N.......
00000140 00 00 00 00 00 00 00 00 31 41 41 30 32 6D 68 73 ........1AA02mhs
00000150 00 00 00 00 00 00 00 00 57 4E 00 00 44 43 00 00 ........WN..DC..
Posted: June 4th, 2016, 17:54
by balgator
Anyone could provide me that fw or advice how to find firmware 1AC28yrB.d11?
Posted: June 4th, 2016, 19:22
by fzabkar
@balgator, can you show us a terminal log for the drive during power-up? BTW, I'm not sure I am asking for the right thing (1AC28yrB.d11). There appear to be other numbers which may be more relevant.
Posted: June 7th, 2016, 12:42
by balgator
Hi guys,
tomorow i will have second PC(notebook) so i will be probably able to capture terminal log for the drive during power-up. I will try to read again MOVLY001/MOVLY007/OVERLAY SA modules.
Posted: June 8th, 2016, 1:32
by fzabkar
Spildit wrote:Hi ! I didn't check the resources but for drives prior to Trinity (classic samsung) overlay module is OVERLAY and not MOVLY001.
I examined balgator's FIT module but it only has references to MOVLY001, BOVLY001 and MOVLY009. There is no OVERLAY module. :?
Looking forward to the terminal log ...
Posted: June 8th, 2016, 13:37
by helpless
Spildit wrote:I think that it will be hard to fix without a proper firmware tool that works with Samsung.
SHT will do the job but costs $200 USD.
Sorry, i don't see any cheaper alternative unless somehow you can find out a way to match ROM with overlay by flashing something to the drive with the vendor tools,
But then again, this would be very easy to fix with something like full version of SHT.
A tool alone will not fix it, he/she will need to download the right microcode to the the hdd.
I doubt if there is any info on the original rom/fw version in the drive. If the update hasn't changed anything on the platters, you have to buy/find at least the correct main code compatible with your fw.
